If you are running a generator it will also feed the CONVERTER which changes AC to DC to power DC items in the coach AND charge the batteries. Your generator (of sufficient power) will run your air conditioning AND charge your batteries at the same time.
First thing to remember is that 1 amp from your AC generator is equal to 10 DC amps to your battery.
Example...let's say you have 30amp AC service AND your generator puts out 30 amps,,,3600watts....
Now let say your air conditioner needs 15 of those AC amps to run...that leaves you still with 15 more AC amps to power other stuff...including your converter.
Now if you have a 50DC amp converter that will take just 5 of those 15 AC amps...so you are still within your 30 ac amp limits. In reality...it will vary a bit but your batts will charge just fine if you have a generator capable or supplying 30 amps, Of course, if you can turn off the air conditioner...you can get by with a smaller generator.
Hope this helps.
BTW,,,the converter is usually buried somewhere close to the AC and DC fuse/breaker panel in your RV.
________
Cam
2015 Georgetown 280DS
