Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Forest River Community Forums > Forest River Lifestyle > Boondocking
Old 09-29-2011, 08:35 PM   #51
too fast turbo sled
f1100turbo's Avatar
Originally Posted by BackInAction View Post
As the OP, here's summary of my plans...
  • I bought another cheap-o Group 24 (and battery box) to match the one that came with the camper. I will wire them in parallel.
  • Added battery on/off switch for storage
  • Will take my small genset for morning recharge (via camper's converter) and to allow my wife to make her coffee.
  • After thinking about it more, I just might swap out 2-4 of the lights with LEDs so I don't have to be as crazy about limiting light use.
  • I'm still not sure about which heater to go with Mr Heater Buddy or the Wave. I'll probably get the Mr. Heater because it is just easier to setup/use. Plus it is half the cost.
I really think this setup will do more than what I need. Besides these two planned trips. I'm hoping if all goes well, my family will be willing to try some more dry camping (SF, NP, NF and a few of the nearby SP).
I just bought some cheap 912 led replacements for .99 free shipping for 2 from hong kong for that reason. when no power is available .
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is online now   Reply With Quote
Old 09-29-2011, 11:19 PM   #52
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Have you considered a small 10,000 BTU kerosene heater such as this one - made by and sold through Northern Tool. No condensation issues and can be used at home for emergencies. Five gallons of K-1 should run it for two full days +, not just nights.
One very patient wife and one furry child who travels with us. Thirty-eight years of trailering and camping, and I still have a blast.
dimurrrw is offline   Reply With Quote
Old 09-29-2011, 11:37 PM   #53
AKA Bluebird
dimurrrw's Avatar
BTW & FWIW Just in case you were thinking about using a 20 lb cylinder and a connection hose.
From Mr. Heater Manual:
This Heater may be used in a recreational enclosure or temporary construction work enclosure with a remote refillable propane cylinder ONLY when the cylinder is located outdoors and the Heater is used with Mr. Heater Hose No. F273701, F273702 or F272702 and fuel filter F273699. Fuel filter must be replaced annually. (NOTE: Do not operate without the fuel filter as fuel contamination may damage the heater.) Or use gree
Old 09-30-2011, 06:35 AM   #54
Where did you order those?
TV: 2008 Ford Expy
Camper: 2012 Rockwood Roo 233S
BackInAction is offline   Reply With Quote
Old 09-30-2011, 08:41 AM   #55
This recommendation seems a bit odd given that the heater will run with attached 1# canisters. Why are attached 1# canisters "safe" but a remotely connected 20# is not? I suspect it is a CYA move. To cover the case in which some idiot would place his 20# tank right in front of the heater.
That said, I have no plans to use a remote 20# setup.
TV: 2008 Ford Expy
Old 09-30-2011, 10:24 AM   #56
AKA Bluebird
dimurrrw's Avatar
I must correct my above post - wasn't thinking too clearly when I wrote it.
Burning kerosene does introduce water vapor that results in condensation, just like propane.
Old 11-28-2011, 06:51 PM   #57
I'm the OP, here the results of our trial trip over Thanksgiving... (3 nights with hook-ups and 2 nights without)
Setup:
I added a second cheap-o Group 24 battery to my camper, purchase 5 10-light LEDs for use in a few select over-head lights. And 3 smaller LED replacements for the bunkend fan/light combos. I brought along by Honda EX700c generator, that I ran for a ~2 hours each day, but I suspect I could have used it less if I had had a "better" battery meter to monitor usage/capacity. I also purchased a Mr Buddy Heater (the largest one).
Lessons learned...
  1. Turn off the "auto" mode of the refrigerator before starting the generator.
  2. My generator won't run our toaster. Never tried to use it with my wife's coffee maker as she switched to something instant from Starbucks a friend of her's recommended.
  3. The heater consumed both 1# containers over night and kept the camper (with the rear bunkend closed) at 55-58F when the overnight temps were near ~35F on its lowest setting with its built-in fan turned off.
  4. I really need to get pop-up gizmos. Bunkend condensation is the bane of winter camping in a PUP and/or HTT. Especially when dry camping (not using electric heaters). Even with the roof vent open an inch and a side window of two bunkends cracked a bit. The moisture under the roof of the bunkends was quite annoying.
  5. The 10-light LEDs were more than bright enough for our needs (especially when used in pairs). I plan to buy a few more to expand coverage (over dinette). The smaller lights in the bunkend light/fan setups were too dim to read by, but did kids though it was good enough for their needs.
  6. I pulled the fuse for the radio, but I wonder if the LED in the control center indicating a missing fuse doesn't draw more power. I don't know if this was the cause, but my water heater didn't work until I re-inserted the radio fuse.
In general I think we could have used the batteries more than we did and we ran the generator more than we needed.
The Elkmont CG within the Smokies was great we camped right along the creek. It was maybe 20% full (and 50% of it was closed off for the season). The kids had a blast and more importantly, my wife said "why don't we camp like this more often" followed by "I think we could do this for a few days." I just about choked on my Smore when she said that.
TV: 2008 Ford Expy
Old 01-24-2012, 11:25 PM   #58
Battery requirement
Although we currently travel in a Bershire 390Bh class A, we spend 7 years in a Trail Lite Bantam (Hybrid TT).
Our experience was as follows keeping in mind that at that time most of our camping was in Western Canada;
Our biggest draw came from the furnace even though we would have it turned off during the day and only on at a very low temp at night.
Our next biggest draw was our 12v TV and VCR.
Refrig. would have been right up there but we alway ran it on propane.
For many years, we ran our trailer with a single 12v battery. If we were careful, we could get two days from a single charge. At which point we would need to start up the van and run it for a period of time.
Since most of the places that we camped at that time did not allow generators, we found that we became captive to semiservice sights.
We found that the best alternative was to to with 2 x 6v deep cycle batteries (high quality). The cost of doing this is marginal. In Canada the cost of the batteries is approx $130 each plus the cost of a second battery box and a small amount of cable.
By moving to 2 6 volts, we were able to get about a week out of one charge.
This along with a genset or small solar panel will be a good option
lefaivre is offline   Reply With Quote
» Online Users: 526
109 members and 417 guests
0721SSROO, 4bnabird, 87CrewDually, accumack, adp1326, armye7, ashump, BamaCorner, BBuck, Bearcat55, biggrigg, bjlowe, briangoodridge, buzzmonster, Cafjackracing, caper, CCrane2299, CHD Dad, chof16, cmptrkd, ColoradoGreg, DAISY BOYKIN, daveg, daveinpickerington, daw592, deerslayer, Dennis Carpenter, dewcew72, Dodge Guy, DonCath25ds, DonG, dunnnc, Elidh, Emptypockets, Falcon35, FR28footer, gerrym51, Glockfanjohn, Great Horned Owl, Great Lakes, gtkato, gvanmeter, Happy Vibe, HemiCab, hitch hiker, hoovercab, Hybrid21SS, Itsthetwoofus, J McClure, jamiller45, Jestercyco, jjm901, jmswms, Joe Gag, jusme, kegoneill, ken0042, kgmat, KKapa, Kricket, lbhird, leencharlotte, lmcleister, Lonewolfcry, Magnetic, Mattpopp, mcbride5, merlin66043, mike7431, MilCop4523, MIwolf, Mkayers, MrAllen, msbates, mtnguy, NanaKaren, OffPavement, pg_rider, Pinesman, Poppy Bill, pwrplay, Reneedann, retiredguy, Rickstermn, rracer5, Rugged Brown, rvinman, SabreSam, Sailfish Bret, Saratoga Camper, sbond, Scriggs1, shawnj72, slogan, Stank Bait, stevengb, Tbeasley77, tentcamper1, TheSasks, tiny, TRAVLINOHIO, Triguy, trudinator, vlite2011, vp22er, wagon52, whj77372, wildwood_man, wnytaxman
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
