09-08-2011, 06:17 PM
Minimal Battery/Electrical setup for a night or two...
Over the next 9 months we are planning a total of 5-7 nights without shore power (in National Parks). Outside of these two trips, I seriously doubt we'll spend anymore than a single night a year without power. I doubt we will spend more than 2 consecutive nights without electrical hook-ups.
I'm trying to determine what sort of minimal setup I can get away with that meets these requirements for my family of 5...
- Assume 5p-9a power usage as I expect we will not be at the campsite during the day or during lunch.
- Handle parasitic loads (detectors, radio standby [though I guess I could add a hard on/off switch])
- Water pump usage (several flushes, brush teeth, wash hands, some drinking water and a small load of dishes)
- Minimal camper lighting usage as I plan to purchase a few hockey-puck LEDs and/or LED lanterns to handle general lighting as that approach appears to be much cheaper than replacing the camper's lights with LEDs.
- Possible furnace usage. <-- This is my biggest variable. I suspect it will be needed some, but I'm hopeful it won't be needed all night. "Put on a hat!"
- What else am I forgetting?
Right now I have the stock battery/electrical setup on our new 2012 Roo 233S (single 12v battery, don't know type). And I plan to bring along our Honda EX700c genny primarily for recharging.
I realize there are quite a few variables, but what else do you think I'll need?
I'm thinking I'll need to add some more battery capacity (tell me if you think otherwise) and come-up with a charging strategy.
- Would another 12v do? Should I hook it up or do the "swap-n-charge" game?
- How long would you expect the genny will need to run to top off the batteries each morning?
- I'm thinking I'd just connect the genny to the camper and let the camper's system do the charging. Unless you think a standalone charger (~$80?) and the "swap-n-charge" routine makes more sense.
Thanks for your suggestions...
TV: 2008 Ford Expy
Camper: 2012 Rockwood Roo 233S
09-08-2011, 06:22 PM
too fast turbo sled
your ex700c is only 700 watts.
only 6 amps ...........
hmmmmmm
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
09-08-2011, 06:29 PM
Moderator
hmmmmmm
That generator should be plenty good to just charge the battery, with no other electrical load. A stand alone charger hooked directly to the battery will charge the batteries a little faster. But as a precaution, I unhook the battery from the camper if I use a stand alone charger. Where the built in converter charger has about 13.6 volts maximum, the stand alone charger may go over 14 volts, which may be too much from some of the camper electronics that might be online. For instance, even though the fridge is on gas, the circuit board runs on 12 volts, as well as the water heater, propane detector, etc.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
09-08-2011, 06:32 PM
only 6 amps
That's what I have, so it'll have to make do.
It keeps my 17yo home refrig working during power failures. That's all I've ever really asked of it.
TV: 2008 Ford Expy
09-08-2011, 06:37 PM
Thanks. Any recommendations on a charger. The only one I have now is a ~$45 I bought from wal-mart a few years ago, I doubt it is one of fancy 3-step things ( Here's the link). Will that do, or should I invest in something else?
Should I pick-up another battery and just swap them in/out? Or maybe put two 12v in parallel (seems like an inexpensive option)?
TV: 2008 Ford Expy
09-08-2011, 06:42 PM
too fast turbo sled
Originally Posted by BackInAction
That's what I have, so I'll have to make do.
Wasn't bashing what you have ....  just was thinking ... It could be tough on one battery . someone on here will have a perfect or close to perfect solution to your concerns !
like previous poster I would use the gennie to charge battery only after being un hooked . I believe you should put a master switch on there and that would help .
If you have to run the heat it might be ok to get it real warm and then shut down .
the toilet we all ways turn the pump on to build pressure then shut it off and normally you can get 2 or 3 before water trickles .
battery operated lanterns are a good idea to conserve .
If heat is not required at night hit the master switch if you install one .
I dont know I am rambling . You'll get plenty of answers on here .
Ron and Amy Benhart
09-08-2011, 06:48 PM
I added a 2 battery bank on my recent camper as my last unit had only 1 battery and it would go dead by morning if the weather was cold and the furnace ran quite a bit during the night. I'm able to last about 3-4 days on this battery bank if furnace does not run much. (once or twice per night)I keep lighting to a minimum and do not use TV. Radio on for about 3 hours per day.
Walt-N-Terry Sanford
03 Dodge Ram 2500 Diesel
08 Rockwood 8317
09-08-2011, 06:49 PM
That's what I've noticed. Plenty of friendly informative responses.
FWIW, I do plan to install a on/off switch on the battery if for no other reason than to keep it from discharging while in storage.
TV: 2008 Ford Expy
09-08-2011, 06:52 PM
Sounds promsing. I assume you just added an additional 12v battery in parallel with the original, correct? What do you charge it with? Or do you just wait 'till you get home and connect it to shore power?
TV: 2008 Ford Expy
09-08-2011, 07:00 PM
too fast turbo sled
FYI I personally would not use the convertor to charge a dead or near dead battery .
I would use a small amp hour charger to slowly trickle it up if you have time.
Ron and Amy Benhart
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 525 |
| 108 members and 417 guests |
| 0721SSROO, 4bnabird, 87CrewDually, accumack, adp1326, armye7, ashump, BamaCorner, BBuck, Bearcat55, biggrigg, bjlowe, briangoodridge, buzzmonster, Cafjackracing, caper, CCrane2299, CHD Dad, chof16, cmptrkd, ColoradoGreg, DAISY BOYKIN, daveg, daveinpickerington, daw592, deerslayer, Dennis Carpenter, dewcew72, Dodge Guy, DonCath25ds, DonG, dunnnc, Elidh, Emptypockets, Falcon35, FR28footer, gerrym51, Glockfanjohn, Great Horned Owl, Great Lakes, gtkato, gvanmeter, Happy Vibe, HemiCab, hitch hiker, hoovercab, Hybrid21SS, Itsthetwoofus, J McClure, jamiller45, Jestercyco, jjm901, jmswms, Joe Gag, jusme, kegoneill, ken0042, kgmat, KKapa, Kricket, lbhird, leencharlotte, lmcleister, Lonewolfcry, Magnetic, Mattpopp, mcbride5, merlin66043, mike7431, MilCop4523, MIwolf, Mkayers, MrAllen, msbates, mtnguy, NanaKaren, OffPavement, pg_rider, Pinesman, Poppy Bill, pwrplay, Reneedann, retiredguy, Rickstermn, rracer5, Rugged Brown, rvinman, SabreSam, Sailfish Bret, Saratoga Camper, sbond, shawnj72, slogan, Stank Bait, stevengb, Tbeasley77, tentcamper1, TheSasks, tiny, TRAVLINOHIO, Triguy, trudinator, vlite2011, vp22er, wagon52, whj77372, wildwood_man, wnytaxman |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
