Old 08-14-2012, 04:00 PM   #1
great white's Avatar
Never boondocked, looking to start, what should we buy first?
I'm just on my way to work, so this first post is going to be short.
I've got a 2011 831RLBSS Flagstaff Classic superlite.
It's just the way it was delivered from the factory.
We're in a place that has minimal setup even at the nicest parks.
electric and water at best. Dump station somewhere in the park.
we're looking to try boon docking.
We have access to a honda 2000 generator (loaner from work).
We're aware of the need to conserve water.
It's just me and the missus and three larger dogs.
Most we will do is a weekend to 3 or 4 days at a time. Basically, a long weekend at most.
Trailer seems pretty self contained as is with the gen added.
I'm looking for a priority list I guess. Like
1. generator.
2. Second deep cycle battery
3. LED lights
4. johnny bucket
5. solar panels
6 inverters
7. Etc. etc......
Sorry for the quick and dirty post. As I mentioned, I'm on my way out the door to work but we're headed out this weekend and I would like to get an idea of priorities before we go.
No doubt, this weekend will reveal a lot of what we need first and what can wait.....
Cheers
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 08-14-2012, 06:20 PM   #2
I'm new to this too - my first trip out was last weekend.
My priority is peace and quiet first, then convenience. If you don't care about noise or disturbing other campers, then just get a generator and forget the rest - the honda you mentioned should provide all your needs.
But if we are like-minded, then:
First thing I'd do is LED lighting - it's a huge battery saver.
Next I'd buy a second battery.
I have a generator, and I went the weekend fine without it, except for wanting to use the coffee maker. I also have the second battery. You can do all your cooking and refrigerator on gas.
My next purchase is an inverter. I'd get that before I bought a generator. If you do get a generator, spend the extra money on a quiet one - the Honda and Yamahas are hard to beat, but they are expensive - ~$1,000 for a 2000watt. Doubt you'd need bigger than that - my Yamaha will run the AC fine.
Since you haven't spent the money on a generator yet, then you might consider solar instead - it would be a bit less to get some serious charging capability, but you have to get a good bit of knowledge to know what to buy, as there really aren't pre-packaged systems or shops to install them for you - definitely a DIY proposition.
Hope this helps you.
crasher is offline   Reply With Quote
Old 08-14-2012, 06:29 PM   #3
Terier's Avatar
With only 1 trip of dry camping under my belt I don't have much experience to share. I did buy a second battery and upgraded the original battery. No problem with limited battery usage on my 3 night stay. Not the best method to use as a guide but I only used up 1 red dot (out of 4) on the senors display. I don't have a generator so it all propane and battery power.
For the short list:
Ditto on second battery & LED lights. A generator would be nice but currently you have access to one which will save you some cash.
Old 08-14-2012, 09:42 PM   #4
Triguy's Avatar
We boondock a bit and dry camp more. You are very correct that this weekend trip will tell you a lot.
It's all about water, waste and power.
See if you can get a handle on your water usage per person on this trip and use that to plan future trips. Depending on your tank sizes and usage, staying three or four days should not be a problem for your gray and black tanks. I would bring bottled water and paper plates to conserve the FW. Maybe a larger water tank in your truck for the future.
You will probably not need a blue boy to empty the GW and BW into on this trip if you are water-conscious.
Make sure to match that new battery to your old as closely as possible in type, size, age and manufacturer. You want both to be equal to avoid one charging or discharging faster than the other. Depending on your usage, I suggest upgrading to the biggest 6 volt or 12 volt deep cycle batteries that you can fit (and afford). My two Trojan T-145's give us 260Ah. They're the biggest I can fit on my trailer's tongue (or I would have bought bigger).
Bring a decent multimeter with you (should be standard equipment in everyone's camper tool box) and use it to record your daily usage between chargings. This will also help you plan for the future. You can find power inventory worksheets to record the data. As mentioned, LED bulbs are a must for a boondocker.
The 2000 watt generator you are borrowing might start your a/c and it might not. You'll learn that this weekend. It will definitely do a good job charging your batteries, however. Probably not to 100% but enough so that you wont over-discharge your battery bank. If you buy one of your own in the future, I second the previous suggestion to stick with a super-quiet Yamaha or Honda (The noise from my own construction gennie bothers me, even if there are no others around to be bothered by it). As for size, it depends on your usage and A/C ( 13.5 or 15kw). If 13.5kw, I would recommend that you consider two 2000-watt units in parallel for the output, ease of carrying and versatility. But then, I don't have much storage space either for the bigger units YMMV. Take a good look at some of the generator threads on FRF. They cover watts, decibels, etc in more detail.
Before you install an inverter, see if you can get by without one using 12v appliances. If you think you want an inverter, there are more threads on that topic, too. Solar is complicated. Consider where you plan to camp (under tree cover or in the open) and a bunch more before you invest in solar. Good topic for another time.
Last, I suggest a book for you... Managing 12 Volts: How to Upgrade, Operate, and Troubleshoot 12 Volt Electrical Systems by Harold Barre. Fantastic read for any RVr.
Boondocking is great fun and I wish you all the best this weekend!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-14-2012, 09:56 PM   #5
Fire Instructor's Avatar
IMHO:
1) Blue "tote tank" - for waste disposal
2) Fresh Water bladder tank - for hauling in fresh water
3) Flo-jet Macerator - for pumping waste into blue tank, while sitting in truck bed, so that you can haul distances.
4) Small 12v water pump for pumping from bladder to fresh water fill.
5) All LED's interior.
6) Replace 12v battery with a pair of 6v golf cart batteries.
7) 2000w to 2400w QUIET generator
8) Solar panels - I have 300w, and they do a great job.
9) 2000w PSW inverter.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 08-14-2012, 11:00 PM   #6
Location: No longer own a Forest River product, but enjoy the info on this site
Boondocking is about needs. if you need it, bring it or be able to get it or in the case of wast - be able to get rid of it.
We rarely boondock more than 3 or 4 nights at any given time so solar is an extravagance - given the fact that we own two generators.
Water or ability to transport water to the camper when dry camping is important.
We have not run into issues over-running the black H2O tank, but grey water seems to fill up faster - so the blue tote is a good idea.
One of our camping friends says his grey water tank 'has a small hole in it' so he'll let loose of some water. We own a blue tote so this makes water disposal possible in most cases.
Enjoy the boondocking!
teamgl is offline   Reply With Quote
Old 08-14-2012, 11:28 PM   #7
2Susan's Avatar
The big water wasters are the toilet and washing dishes.
For the toilet, not having the water pump on saves a bunch. We use wipes (unscented) and put those in the garbage, using one if needed to wipe out the bowl. So no paper products in the toilet at all. When I do dump I back fill and rinse the black tank several times. Get one of those connectors that is see through and has a hose connection (they sell them at some walmarts). Also use a different hose from the one you use for fresh water. This hose doesn't need to be terribly long. Also when it's time to travel I add 5 - 10 gallons in the black tank until we get to the next stop for that swishing action.
Dishwashing wastes a huge amount of water - so minimize the need. Consider disposable plates, cups etc. If not disposable consider each person having their own water bottle, mug. Use a paper towel/ napkin to wipe the mess from the dsihes expecially if it's greasy. You mentioned 3 cannine dishwashers (err dogs). Generally washing things immediately uses less water than if it's dried on.
I have several dishpans. One is set out with soapy water before the meal - everyone uses it for handwashing before eating. After dishes are scraped and wiped with the napkin/paper towel, this becomes the prewash water. Depending on how many dishes and how dirty there may be just one dishpan for rinsing or two. I generally do this outside. As the wash water gets really soiled, that gets dumped and rinse #1 gets a squirt of dish detergent and becomes the new wash water.
When preparing meals consider how you can re-use the water. For example the water from pasta can also cook veggies. Veggie/pasta water can become the water used to make soup/stew.
Don't plan on showers! Don't let the water run while you brush your teeth.
I have 3 children and we have a bucket or a buspan near the door so they can wash sand and dirt before entering.
I have a clip on LED light for late night reading which I have been using since last fall, so those 3 triple a batteries have lasted a long time.
We do not always use the generator. Often just to run the microwave. I now have a french press coffee maker - left the Keurig at home and so we just heat the water on the stove.
2Susan is offline   Reply With Quote
Old 08-20-2012, 06:51 PM   #8
Paul & Sheri
pwb01's Avatar
LED's as mentioned are very important to save power. Pull the second bulb in two fixture lamps and use lesser watt bulbs where they aren't replaced by LED's. Also get an accumulator tank for the water system. They store energy for your water pressure. The pump runs steady to pump in pressure and shuts off. Without one the stop/start action on the pump uses max amperage every time it starts so minimizing starts saves power. To cool the unit down on hot nights consider a high capacity vent fan or the Fan-Tastic Endless Breeze 12v portable box fan. I've used as many as 4 batteries for power lasting a week with some power to spare. You could need a few hours a day running a genny to top off two battteries.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 08-31-2012, 09:09 AM   #9
Go Pak
unyalli's Avatar
I'm a bit new to this as well. Don't know the size of your tanks but my 2013 2501SS has 36 fresh, 35 grey, and 35 black. We need to take a shower after the day is done to get the sunscreen and sweat off for the evening. The best thing I bought so far is the Oxygenics shower head. DW and I did our first true boondock this year for a standard weekend. We use all disposable stuff and take out all we bring in. We use bottled water for drinking and cooking. Both my grey and black were just at the 1/4 light when we left. Fresh was 1/2 so I drained a bunch of water on the ground. Second best could be the single cup drip coffee maker. Thing sits on top of a coffee cup and uses a cone filter and you fill the cone with water heated in a tea kettle on your stove.
As far as electricity goes I've replaced all my lights with LED's and have a CPE Category 5 2000w inverter generator ($650.00) to charge my single battery in the afternoons. We spend all our time outside so no need for A/C but do turn on the fantastic fan in the evening to help cool down the interior before bed. I will be going the dual 6 volt golf kart batteries from Sams Club or Costco and solar next summer.
Oh ya, one more thing, the wife loves the patio mat. Runs around barefoot on it.
Jeff
2016 Cougar Ultralite 26RBI
2015 F150 Lariat 4x4 CC Ecoboost 3.5L
unyalli is offline   Reply With Quote
Old 09-01-2012, 11:32 AM   #10
biken201's Avatar
Water.
With the generator you won't have issue with power for the lights, furnace (if needed) and such.
We bring a 7 gal jug of water for the dogs (4 large akitas) and just bought a 5 gal jug for our own drinking water. We have been bringing gallon jugs (from the store) of drinking water, but that just takes up space in the camper. With the 5 gal jug we are able to fill it from our own tap (if you choose) and/or dump a bag of ice in it and fill with the rest with drinking water. I keep the jug on a table outside the camper (next to the grill) and 1 liter refillable bottles in the fridge for drinking. 5 gals will last us a long weekend (at least).
If you are boondocking within a reasonable distance to a store, or other place where you can restock if needed, water won't be such an issue. But where we go, there's no such resource, so plenty of water is a must. The 36 gals in our FW tank will usually last about 3 days (showers and toilet).
We bring a separate 7 gal jug of water for dishes and FW tank supplement (if needed). Washing dishes is a HUGE waste of water. We learned early-on that disposable plates and silverware are a must. I have a small plastic sink that I use for the few pots/pans that need to be washed.
Our total water is as follows;
36 gals (FW tank with hot water heater)
7 gals (water for dogs)
5 gals (drinking water for us - 2 adults)
7 gals (supplemental water)
I realize that is a lot of extra added weight, but we usually don't go anywhere that water is readily available if needed.
11' Dodge Ram 3500 DRW 6.7 Cummins
12' Rockwood Roo 233S
Current: AZ
Wife: NY
Me: IL
3 Akitas (RIP D-Dog)
biken201 is offline   Reply With Quote
