Originally Posted by HappyCamperCanada
What's a proper battery monitor? What's the difference between it and a multimeter?
Expanding a little...a proper monitor like the Victron will tell you the following.
1. The PRESENT state of charge of your batteries while in use. Meters only do this to a WELL rested (24 hours) and disconnected battery bank.
2. It will tell you when you've reached 100% charge...so you don't undercharge and kill batts and you don't overcharge and waste genny gas and life.
3. It will tell you how many amps you are drawing now,
4. It will tell you how long your batts will last at the present rate of draw.
5. It will give you NET amps in and out if you are running the genny or solar.
6 It will tell you the amp draw of individual items when you trun them on and off. It will also show you your parasitic draws when you turn everything off.
IMO...if you boondock...the meter will pay for itself. SOME of this you can accomplish with a meter..and some running around. The most important things you can't.
If you don't boondock...a meter is all you need. If you rely on cycling your batts...it will be your most popular "tool".
