Old 03-12-2017, 06:03 PM   #1
Residential refrigerator and boondocking
Not planning on boondocking often and the just for single night but I was wondering how long a residential refrigerator would run off of the batteries without a recharge? There are two heavy duty batteries standard with our new motor home. Will these last over night?
BMW Rider is offline   Reply With Quote
Old 03-12-2017, 06:26 PM   #2
Rich.M's Avatar
That's gonna be close. Last I checked residential refridge on inverter drew about 162 amp hours in 24 hours without any other power use. Add 25 to 50 amp hours for lights and extras and your up over 200 amp hours . If over night is 8 hours and batteries are healthy then you may be ok but start the generator or get moving early. The inverter will cut out if low voltage and that may be easy to trigger with only 2 batteries ( usually 100 to 110 amp hours each. ) Suprised you only have 2 batteries with a residential fridge. Many have 4 , what rig / motor home do you have?
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 03-12-2017, 07:29 PM   #3
I have four six volt Trojans and just running the residential refrigerator the batteries will last four days. For one night it's no problem for my batteries
spock123 is offline   Reply With Quote
Old 03-12-2017, 09:09 PM   #4
The_Rhino's Avatar
Lots of factors to consider like outdoor temps, size of fridge, condition of batteries, etc. Last year I replaced a failing Dometic 8 cu. ft. RV fridge with a $300 open box Whirlpool 11.8 residential connected to a $100 2000W inverter running off of (2) 12V batteries. It's ready to pack in 1 hour, lots more space inside, & it lasts over 1 day on a hot beach with just (2) 12V batteries. I found WEN Yamaha 2000 clones for $375. One charges the batteries in 2-3 hours & two will provide 30A for the A/C if the temps get too miserable...
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2018-25
2017-31; 2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
boondocking, refrigerator
