Old 09-09-2018, 03:55 PM   #1
Solar plug on the side of my trailer?
My trailer has a plug on the side for solar. I have looked through all the info that came with the trailer but cant find anything telling me what will fit it. I would like to find something that will help keep the batteries charged during the day when I am not running the generators. Has anyone used that plug? What would I need to buy to utilize it. I have never used any kind of solar equipment before. Dont want to spend a bunch on it, just something that will help keep the batteries up in the daytime. Thanks.
"Slightly Modified" 2013 Ram Cummins MegaCab
2018 Heritage Glen 372RD 43ft.
k_allison510 is offline   Reply With Quote
Old 09-09-2018, 04:39 PM   #2
I think a zamp connector will plug into that. get a 100 watt solar suitcase and put the zamp solar connector on it and should be golden. Now some trailers came wired with a solar charge controller, might want to chk if you have one. I would think you do, if that came new on the trailer
Craigrrr is offline   Reply With Quote
Old 09-09-2018, 04:46 PM   #3
Yeah, Zamp is the only one I've ever seen pre-installed. If you don't use a Zamp system, remember Zamp reverses the polarity just to be different. Research first.
wherewolf17 is offline   Reply With Quote
Old 09-09-2018, 04:46 PM   #4
Herk7769's Avatar
That is because it is just a wire that goes to the battery.
You have to be kidding me!
The MUCH hyped "solar prep" is just a place to plug in a complete system that includes the panel and solar controller.
https://www.rvautoparts.com/ZS-RV-RO...oaAtG-EALw_wcB
I will be disconnecting the wires from the battery and attach it to an MPPT solar charge controller. That way I will only need to connect the panels to the outside connector and not the entire system.
HAM CALLSIGN - KC3FFW
Old 09-09-2018, 04:58 PM   #5
It says furion on the plug if that matters. I dont have to use the plug. Just thought it would be handy since I have 2 batteries. I didnt even know that I needed a solar controller. So learned something already.
Old 09-09-2018, 05:02 PM   #6
And I am fairly certain that I dont have a controller pre installed.
Old 09-09-2018, 05:28 PM   #7
I just finished doing that. I left the Zamp "port" installed and just got an "SAE Connector kit (two rubber connectors on a loop of two wires) from the Auto Parts store. Looks just like a flat trailer wiring connector but with only two wires.
Matching polarity is no big deal. Just make sure to match the + from the panels to the + connection on the Controller. Wire color doesn't matter if you are using a meter.
I have it on my dog's authority that an afternoon nap is acceptable.
Politically Incorrect since 1943
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-09-2018, 05:34 PM   #8
So I have been looking through some solar kits on Amazon. I found the adapter that will plug into my port. But most of the "suitcase" style kits that I am finding have alligator clips. I am still confused about the solar controller to. Some have it mounted to the panel. And some say to mount it to the trailer. I would like something that I just plug into the port and "set it and forget it" type of thing. I dont really have a set budget in mind. Could I get something that I am looking for for $500? Thanks guys.
Old 09-09-2018, 05:37 PM   #9
Herk7769's Avatar
It is a thinly veiled advertisement for a profit add at the dealer. The "suitcase" solar panel sold by dealers has the controller installed under the panel.
https://www.amazon.com/Renogy-Watts-...907218730&th=1
Amazon has a similar sized suitcase for more than half the price of the ones carried by RV dealers. Shop around and you will find you can build your own for even less.
Old 09-09-2018, 05:45 PM   #10
Herk7769's Avatar
Once you install the controller inside the compartment, it will be plug and forget. Well, Plug and turn and turn and turn …..
You will still need to put the panel(s) in direct sunlight and turn it as the day progresses to get as close to 90 degree incidence as possible.
The controller only has 4 connections. Two go to the panel and two go to the battery. The hardest part is finding a place to screw it to the wall and making sure the Plusses go to plusses and minuses go to minuses … LOL
You can buy the panels for about a dollar a watt delivered (https://www.amazon.com/HQST-Watt-Pol...ds=solar+panel) and a good MPPT controller is about 30 bucks (https://www.amazon.com/AOSHIKE-Contr...70_&dpSrc=srch)
So a wire it yourself 100 Watt system will set you back 140 bucks tops.
For the price of the 100 watt suitcase all in one "just plug it in" unit, you can get a 325 watt 1 panel system (https://www.amazon.com/dp/B07CCH3YBQ..._t2_B00ZIZ6VY6) plus the controller. (NOTE - You will need to pick it up in CA (LOL) the shipping will kill ya.)
https://www.amazon.com/Newpowa-Solar...CE61C32VCMTQWJ
Here is 160 watt panel ships free for 164 dollars.
Herk
solar, trailer
