Old 06-03-2016, 06:01 PM   #111
The first Roo they sent us had a sticker that said a full load of water weighed 249 lbs. The tank measured 28x54x6. Do that math.
The person in charge of doing the math for the sticker evidently did not excel at math.
Moral of story. Just because you think its an official weight or capacity don't put much trust in it.
Mr Havercamp is offline   Reply With Quote
Old 06-03-2016, 06:17 PM   #112
W5CI's Avatar
I never have more than 1/4 tank of water, usually less, just enough to flush toilet while enroute ID necessary. But if Dry camping it's still low until I get to where I am going ,then top it off before arrival. Just how I do things
2004 Cedar Creek 30RLBS
2015 RAM 3500 DRW 6.7 Cummins
Amateur Radio W5CI
2016 Days Camping 48
W5CI is offline   Reply With Quote
Old 06-07-2016, 10:35 PM   #113
Too Tall's Avatar
I've never had an issue carrying a full water tank with past RV's. FR has some redesigning to do.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 06-28-2016, 07:42 AM   #114
Originally Posted by Mr Havercamp View Post
Maybe you should of left it full, so you would know if you ever needed to haul a load it doesn't fall out the bottom of the rig?
OP, for a salesman to mention something like that after the sale it sounds like he knows something. Like a design issue with that model.
I didn't even get the "first" trip with our 2016 2504S before the brace bent, but the tank split at the corner of the low point drain. DO NOT stuff the water hose and crank up the water unattended! The tank vent system will not keep up with the volume. The tank will go round and bend the supports. We boondock and always tow with a full water tank. That said i beefed up the tank supports.
Grizzzman is offline   Reply With Quote
tank, towing, water, water tank
