Old 05-22-2016, 10:27 PM   #81
Too Tall's Avatar
Originally Posted by Mr Havercamp View Post
The conclusion I came to was my tank issue was a combination of two things. First off the Lippert (LCI) supplied tank support frame is not strong enough to support the tank. On our 2017 by dimensions we have a 39 gallon tank. When the supports bent it was only 3/4 full or 250 lbs or so. I do not think it would of came all the way out, but you never know. LCI made that support frame out of 1/8" thick plate bent into an angle and I don't know where they buy their steel, but it's some soft stuff. I left it at my sons thinking he might have been able to use it for something on his race cars, but he tossed it in the scrap pile when he noticed how soft it was. Secondly Rockwood used a cheap water tank with some unusually thin walls. The thing really balloons out. They had it jammed up tight to the underside of the floor and that along with only two light cross supports added to the issue. The tank I added made by Alpha systems is much more substantial, does not balloon out anywhere near as much as the stock one Rockwood used, and appears to have walls twice as thick.
Tube is not an option on the Roo, we do not have the frame height and using tube the tank would be too low to the ground. Nothing wrong with angles it just needs to be the right type. They used thin plate bent into an angle. Rolled angles are inherently stronger.
This describes exactly the problem I and many others had also. Very light plastic distorts to the point I'm worried about it rupturing or worse, pushing the floor loose as I can hear strange noises in the floor when I fill it. The metal is less than 1/8" thick.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 05-27-2016, 09:54 AM   #82
WolfWhistle's Avatar
Flints problem is lead, not feces. There's a reason many wise men only drink vodka... or beer.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 05-27-2016, 10:03 AM   #83
Even the water used in vodka and beer had once floated a turd or two.
Mr Havercamp is offline   Reply With Quote
Old 05-27-2016, 10:28 AM   #84
northstar1960's Avatar
even bottled water floated a turd or two . to think it's any safer to drink bottled water then tap is just a false since of security .
northstar1960 is offline   Reply With Quote
Old 05-27-2016, 06:40 PM   #85
I think I'll have another beer or a glass of buttermilk
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 05-27-2016, 06:42 PM   #86
Todouble's Avatar
Buttermilk??? Gross!
Todouble is offline   Reply With Quote
Old 05-27-2016, 07:59 PM   #87
B and B's Avatar
Buttermilk is good!! Yummy with chocolate cake!!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-27-2016, 10:19 PM   #88
I don't drink water - fish $H!T in it!
2011 Traverse LT, 3.6L, FWD
Old 05-28-2016, 02:40 PM   #89
DW goes to church every Sunday, when our friends from church come over and ask what I'm drinking I say buttermilk, last glass
Old 05-30-2016, 09:41 PM   #90
Too Tall's Avatar
Yeah they got lucky
USMC 68 -70
tank, towing, water, water tank
