Old 07-13-2019, 10:56 PM   #1
Water tank problem
I have a 2010 Chapparal 267RLS 5th wheel. I continually run out of water when boondocking. We are very thrifty with water usage as it only has a 33 us gallon tank. The problem is that when I get home and drain the tank I still have about 10 or more gallons left in the tank. Does anyone else have this problem? It has always been like this for what I can remember.
Ronk24 is offline   Reply With Quote
Old 07-14-2019, 04:50 AM   #2
fonzie's Avatar
Here is a thread showing how some people have modified their fresh water tank to provide more water for consumption.
2009-10 Roo 19 fresh water tank outlet location (to pump)
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 07-14-2019, 03:38 PM   #3
Is your water tank mounted underneath the trailer floor, hanging down onto support rails?
If so it's possible that the bottom of the tank is sagging between the supports and the pump intake ends up above the pools formed.
Again, if this is your setup, adding support (like plywood) under the tank that holds it's bottom flat will alleviate the problem.
If your tank is mounted in a compartment, above the floor (as it was in my old trailer) you might have to relocate the pump inlet. Install a glue on flange on top of the tank then create a suction tube that will extend to the bottom of the tank, extending through a compression fitting. Cut the end of the tube at a 45 degree angle so it doesn't seal itself off at the bottom of the tank. PEX works great but I've seen this done on boats using stiff polyethelene tubing. Water is sucked out of the tank just like fluids are sucked up from spray bottles.
One question, are you running out of water while the gauge still shows you should have water? If so, then you definitely need to relocate or revise the water suction "port".
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-14-2019, 05:28 PM   #4
Thanks I’ll check that out
tank, water, water tank
