11-14-2018, 02:51 PM
#201
Originally Posted by Jay2504
Looking at the diagram posted by 5picker I am surprised to see how simple it is. I thought that there had to be some way for the 2 generators to communicate so the phase of the output would be the same. How then is that accomplished? Jay
The second generator detects the phase output by the first generator and matches it.
2018 Surveyor 266RLDS
2017 Palomino Puma 295BHSS
2013 Jayco Eagle 324BTS
2014 Flagstaff V-Lite 30WTBS (broken and TOTALED)
2008 Surveyor SV-234 (SOLD, but not forgotten)
2016 GMC Sierra SLT 2500 Crew Cab 4x4 Duramax
11-14-2018, 02:53 PM
#202
Let me be clear that this is my assumption based only on observation.
11-14-2018, 03:29 PM
#203
[QUOTE=TitanMike;1972372]Just a note on this these Champion Inverter/generators, the Parallel Kit for their 3400/3500 watt units has a 50 amp receptacle for those who have larger trailers and want to run both AC's at the same time along with the usual accessory use when off the grid.
This is a great price for a great inverter/generator. After over a year of use on mine it starts almost immediately with no lengthy cranking and nice and quiet. For those who find themselves in close quarters but still need to run a generator, there is an exhaust extension that makes the use of a 'Gen-turi' exhaust possible. My dog groomer uses a similar setup in her mobile grooming trailer and it routes what little exhaust noise there is up and above, along with any noxious gases. Her setup is quieter than most dishwashers I've encountered.
Thanks do you have a link for the exhaust extension? I leave mine in the back of my truck sometimes. That might be a great addition.
Tank
11-15-2018, 09:20 AM
#204
Tank
this should get you started.
https://www.amazon.com/Camco-Gen-Tur.../dp/B000BUU5XG
I camp to burn off the CRAZY!
Somewhere there is a Tiki Bar and a Jimmy Buffett song that needs me...
2019 Cherokee 274DBH
11-15-2018, 09:27 AM
#205
I run a pair of predators. Can run AC. They work great. We keep the oil changed a ND service the units often. No problem after two seasons and 25 hours of use. COSTCO has the Yamaha for 399.00 this month.
11-15-2018, 09:46 AM
#206
Originally Posted by DonD
Thanks I appreciate the info.
Tank
11-15-2018, 11:45 AM
#207
Tank
You will need this extension to attach to the generator and then attach the Gen-turi "stack" to it.
https://www.amazon.com/Valley-Replac...N0WZ3Q61NR1RWR
The Gen-turi will need some vertical support but it shouldn't be too hard to improvise a "Tripod" or even support it by attaching to a ladder. Because the Gen-turi by design sucks in some cool air along with the hot exhaust, the "stack" runs relatively cool so no extensive insulation is required if braced by an RV Ladder etc. A stiff pipe support bracket from a hardware store can be used, even "plumber's tape" (the metal stuff with lots of holes).
At ground level the "pop-pop-pop-pop" of the single cylinder exhaust is reduced to nothing and now all you hear is the mechanical noise that remains from the engine which is pretty much suppressed by the enclosure. Fumes are dissipated above the RV(s) where any breeze carries it away.
11-30-2018, 11:52 PM
#208
I ordered the Firman 3000 watt inverter with rv plug from electric generators direct. $559 American company with Kohler motor. Check out the reviews. Comes in Monday can't wait
12-01-2018, 01:33 AM
#209
Electric Generators Direct website shows them for $699.
How did you get yours for so much less, from them?
12-01-2018, 12:27 PM
#210
It was on cyber monday
12-01-2018, 01:44 PM
#211
Originally Posted by Beachbourbon
I’ve been doing lots of research on this to ensure I can run the AC, etc. I narrowed it down to three inverter/generators: firman 3200w, champion 4000w and the predator 3500w. They are all similar price points and can run the electronics cleanly, but the Predator is much quieter. I passed by one running at a campsite two weeks ago, and it was as quiet or quieter than a Honda. The Firman and Champion sound like rattlecans by comparison, but I only heard these on YouTube videos. You can get any of these for under $700. The other thing to consider is fuel consumption, and these are all among the best I found for efficiency.
I have run the predator 2000 paired together for the years with no problems. They are quiet. Recently COSTCO put the Yamaha 2000 on sale for 399.00. They are also very quiet and come with the pairing kit.
12-01-2018, 03:32 PM
#212
It's not a Yamaha.
12-01-2018, 04:05 PM
#213
Yesterday i purchased a Honda 2200 from Northern tools.
They included a $200 gift card with the generator which brings the price to $800.
Sort of felt we would need it next year.
12-01-2018, 04:35 PM
#214
As was said, it is NOT a Yamaha generator.
Costco has carried two Chinese-made 2000w inverter generators, that have Yamaha engines.
One is a Smarter Tools Chinese-made generator with a Yamaha engine and the other is an Ai-Power Chinese-made generator with a Yamaha engine.
Smarter Tools is red, Ai-Power is blue.
Both have clearly marked on the box "POWERED by Yamaha".
12-01-2018, 05:05 PM
#215
Well not entirely true , Firman is a wholly owed subsidiary of sinonach company , been building generators for 17 yrs but just started in 2015 building in the USA . they have built generators for Kohler but they do not use kohler engines they are Firman engines .
12-01-2018, 07:08 PM
#216
Didn't see anywhere where it said it was a kohler engine. Just said Firman engine, which usually means Chinese.
12-02-2018, 01:40 PM
#217
My mistake I was looking at a guys you tube video and he said Kohler [emoji53]
12-02-2018, 02:25 PM
#218
No problem , gotta be accurate around here as you'll get pounded by some for not being precise . just trying to save you from the know it alls
12-02-2018, 07:58 PM
#219
Lol Mr M.
Calling some one a know it all for simply wanting to clarify something is a stretch. Big difference between a kohler and Chinese.
What's funny about this thread is you are the one that made the know it all statement. Giving the history of Firman gen sets and all. Then you accuse pounding when none took place, oh except when you just did it.
You are the only one guilty of the claimes you made and don't even realize it.
You win the forum comment of the day.
12-03-2018, 10:15 AM
#220
Originally Posted by KirkT
Lol Mr M.
and i mentioned that because of posts like yours
