Originally Posted by timm9
I did purchase the Micro Air and installed on my 13.5 AC. Tested it at home and the AC did run with the one Honda eu2000i and also ran AC with one Generac 2200. Dry camped at 7000 feet the following week and found that neither the Honda or Generac would run the AC which I assume is due to loss of power at higher elevation. I'm on the hunt for a second 2000 with a parallel kit and curious if the existing Honda can be paralleled with another brand? I have read the entire thread and really prefer not to have to lift a 100 pound gen-set if it can be avoided so the 3500 are out...
Thanks!
Tim
Buy a Honda eu2200 COMPANION model. It comes with the 30 amp socket and will parallel with only an inexpensive wire set. The extra 200 watts will come in handy at altitude and you can use your microwave with the AC running.
https://www.rvpartscountry.com/Honda...Companion.html
The Honda will not parallel with competitors generators.
Also, because the Hondas are the only 2K generators with an internal fuel pump, it can suck fuel out of a pony tank. Get the one that will feed dual Hondas.
https://www.rvpartscountry.com/Honda...RoCub0QAvD_BwE
