09-16-2018, 09:26 PM
#161
Originally Posted by k_allison510
Its returned. Told the people at home depot what was going on. They said ok and took it back. No problem at all.
Oops. My post was late. Good move.
2018 Surveyor 266RLDS
2017 Palomino Puma 295BHSS
2013 Jayco Eagle 324BTS
2014 Flagstaff V-Lite 30WTBS (broken and TOTALED)
2008 Surveyor SV-234 (SOLD, but not forgotten)
2016 GMC Sierra SLT 2500 Crew Cab 4x4 Duramax
09-16-2018, 09:31 PM
#162
Good deal! You are definitely luckier than I would of been with that return . Hopefully the new one treats you right.
My two Honda's are over 12 years old and we use them A LOT. Even I am surprised they are still going strong after the thousands of hours we have on them. All we have done is regular maintenance and replaced the pull cord. Hope you have a similar experience with yours.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
09-17-2018, 06:51 PM
#163
Question for you guys running the westinghouse igen 4500. How do you like them? Do you have the updated version with the 30 amp plug the right direction and the battery cut off switch? They get mostly good reviews and I am leaning towards getting one.
"Slightly Modified" 2013 Ram Cummins MegaCab
2018 Heritage Glen 372RD 43ft.
09-25-2018, 04:43 PM
#164
I'm sure its been posted but I like the 2 Hondas I have they work great and are easy to lift . 1 is the regular Honda the other is a companion . My friend has the EU2200's and they work the exact same as mine except you can shut off the fuel and run the carb dry which I like because these little tiny carbs gum up pretty easily .
TV:GMC 2500HD Duramax
TT: 2015 Wildwood 21rbs
09-25-2018, 05:14 PM
#165
The ability to shut off the fuel and run the carburetor dry was one of the check-boxes for me.
I just picked up a Champion 2000/1700 watt “Cube” which has this feature. Surprisingly it takes almost 5 minutes at an idle to run the fuel line and carburetor out of gas..
This genny is easily as quiet as my buddies Honda 2000... We’ll see how it goes..
Regards - Randy
Cedar Creek Cottage 40CFE
Thor Vegas 25.5
Randy’s Rod Shop & Fabrication
09-25-2018, 06:13 PM
#166
Trailer Park Supervisor
Bought a pair of Champion 2000W inverters and a parallel connector. Scored the generators for 350 bucks each at Blains Farm and Fleet. Haven't fired them up yet, but should be more than enough to fire up 13.5 BTU A/C if I go off grid, which was my only reason for getting them. TV runs off of 12V.
Yes, I drink the water!
09-25-2018, 09:14 PM
#167
Since most small engines don’t have a shutoff I install one along with a fuel filter. Both were very inexpensive at Amazon. Some small engine, like my lawnmower have a direct feed out of the tank and there is no way to install a filter or shutoff.
10-08-2018, 01:25 PM
#168
Just a follower...
I read through this whole thread and bought the 3500 Predator. Very happy with it and everyone comments on how quiet it runs even under load.
10-08-2018, 01:37 PM
#169
Wow this thread got long!!! Bear in mind when choosing your generator, the decibel scale is logarithmic. Every 3 decibels, the perceived loudness DOUBLES. EX: a 63 decibel generator will be DOUBLE the loudness of a 60 decibel unit. Get the most quiet inverter generator you can afford if you will be camping near others. Nobody wants to hear your generator.
10-08-2018, 02:23 PM
#170
I wish you good luck....
My luck is not good enough to gamble on a 90 day warranty..
Regards - Randy
Thor Vegas 25.5
10-08-2018, 02:24 PM
#171
Yep... Sound pressure levels are not as linear as people think.
Regards - Randy
Thor Vegas 25.5
10-08-2018, 05:39 PM
#172
Hence the reason it's measured in DB which is logarithmic.
10-09-2018, 10:42 AM
#173
I thought thegamble was - will something that costs three times as much last three times as long?
I hope i dont need the warranty but I will post if I made a mistake in buying this.
10-11-2018, 05:59 PM
#174
I dont blame you a bit. I would buy a predator in a heartbeat if they made one with higher output. As of now. I kept the companion model Honda that I am going to use when we dont need ac. But I am going to buy the Westinghouse igen4500 in the spring when we start boondocking again. To say that I am unimpressed with the Honda's is an understatement. I regret buying them but I am stuck with the companion.
10-11-2018, 07:42 PM
#175
Powerhorse 3500i
My Predator 3500i is over a year old and has and continues to operate flawlessly ( I suppose I wasted the extra $ on the extended warranty.). If you have concerns with needing parts for an engine repair, Please check out the Powerhorse brand at Northern Tool, other than being blue instead of red, it is identical to the Predator. Parts are available from Northern Tool, so issue resolved.
Good Camping ...... Swampy
Jim (Swampy), Susie, Jimmy & The Chihuahua Crew
2008 Chevy Silverado LS, 4.3L, V6, 2WD, 3.23:1
2014 287 BHBE; 1981 JayRaven: Predator 3500i - Call Home Pearl River, Louisiana. on The Honey Island Swamp
https://www.forestriverforums.com/at...pic81807_1.gif
10-11-2018, 07:52 PM
#176
Just my opinion but extended warranties are usually just "enhanced profit" for the mft/retailer.
If you bought a real lemon there's a good chance you will be covered by the mfr's warranty.
Follow operating and maintenance instructions. Do that and chances are great all you'll have issues with is an occasional loose screw, nut, bolt, etc
The generators I bought, two of them, are 2 years and 13 years old. Not a single issue, not even a warranty claim.
The "extended warranty" hard sell at Harbor Freight is why I hate going in their stores.
10-11-2018, 08:01 PM
#177
I've used a Yamaha 4500 Inverter for the last 10 years with no issue. It only has 650 hours on it and I change the oil every 50 hours. It's super quiet and fits in my storage compartment and is on wheels. It will run both my AC units (15k and 13.5k) at the same time, but that's about it. If not super hot, I can run just the one AC and anything else I may need.
2014 Cedar Creek 36CKTS
2005 Silverado Duramax Dually
10-11-2018, 09:25 PM
#178
It's only a hard sell if you let it be
10-12-2018, 04:06 PM
#179
I agree.
Their job is to ask you about it.
All you have to do is say no.
10-29-2018, 12:36 PM
#180
Is it possible to parallel a Honda and a predator
