Old 05-05-2016, 08:15 AM   #1
Where to start
I apologize upfront if this topic has already been covered but I'm really excited about starting to boondock.
For the last 12 years all we have done is to go to private campgrounds with full service hook ups. I've heard pro's and con's to generators and solar,etc but I'm just not sure where to even start and what to expect when it comes to using the rig (e.g. Water supply, can i run the a/c, etc).
Any advice or direction for a newbie is greatly appreciated.
bmbdcj is offline   Reply With Quote
Old 05-05-2016, 08:37 AM   #2
clr
Most boon dockers do not use the AC. The AC requires a pretty good size generator to operate so most just pass on using AC. You have to learn to conserve your power and water supplies if you are going to boon dock. Most use a small generator to charge up the batteries and such. Solar helps to also charge the batteries and will prolong how long you can go without running a generator. You may want to boon dock (trial run) in a campground someplace until you learn the ropes of boon docking, just a thought.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-05-2016, 08:54 AM   #3
Flybob's Avatar
Make a list of must run and nice to run items then check the specs on the power usage on each. Next estimate the amount of time you will be using each item daily. Now multiply the # watts for each item by the usage in hours and you will know your requirements. If running on batteries, you will need roughly twice that capacity so as not to drain batteries too low. Now you can figure how you want to replace that energy ( solar or generator). When making the solar /generator decision, you should consider where you will boondock. Clear sky view or full shade, neighbors or not, generator restrictions or not. You can do the same with water. While at the full hook up , fill water tank and disconnect public water, Drain waste tanks and close valves. Now you can judge how long your water supply and waste tanks will last.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-05-2016, 09:17 AM   #4
That is a pretty big question. A lot depends on how many days you want to be "off the grid" and what you have and how you use it. If you want to talk about running the A/C, a generator is really the only practical option. Considering your location, the A/C is probably a necessity so I would start there.
It would really help to know what you have.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 05-05-2016, 09:20 AM   #5
As a boon docker you first need to understand EVERYTHING needs to run on either 12VDC or propane. Anything run from 120VAC you will not want to run. Next you need to figure out how to replenish the batteries. For basic battery charging a 500 dollar 1000 watt Honda generator will do just fine. If you insist on peace and quiet, solar plus a large battery bank is the best option. But this can be cost prohibitive for the budget minded camper.
How remote you want will somewhat dictate water useage. We used to camp a lot in NF campgrounds that had water available. Then we simply carried 5G water jug or enough hose to fill the on board tank.
donniedu is offline   Reply With Quote
Old 05-05-2016, 12:31 PM   #6
Wow! Apparently there is a lot of things to consider ( and some math ) when boondocking. I think for the most part I would only be looking for extended weekends to get away however with summer coming on and being in South Florida it may not be in the cards again until next winter when I can go without the a/c.
I really appreciate everyone's comments and thoughts on the topic
Old 05-05-2016, 12:51 PM   #7
bikendan's Avatar
We don't boondock but we do dry camp most of the time.
We have two 12v deep cycle batteries, a Honda 2000i generator, a Barker 15 tote tank, a 6 gallon water jug and a 400w inverter.
We can go a number of weeks straight without any services.
So we would need these things if we decided to boondock.
Equalizer WDH
Old 05-09-2016, 08:29 PM   #8
We designed around 4 nights dry camping with our little A-frame. Stock water tank and hot water heater (15 + 6 gal) will give us more than enough water if we bring milk/juice/soda/wine for meals (and drink water the rest of the time).
We have 2 6V 232 AH golf cart batteries to keep the heater going for 5hrs per night without taking batteries below 50%. With the 2 battery setup, no generator or solar to worry about or carry for the 4 night stay.
A couple of ice-efficient medium size coolers and the fridge, plus a cardboard box or two of dry goods takes care of food and ice for that duration.
Reality is that we never spend more than 4 nights in one place, so the 4 night plan works for us. Too much to see and do to stay in one place that long. And the A-frame is so easy to setup and take down.
Fred W
2014 Rockwood A122 A-frame
pgandw is online now   Reply With Quote
Old 05-09-2016, 08:44 PM   #9
Hey, Dan. Maybe I don't fully understand the definition of "boondocking," but several weeks without services sounds like boondocking to ME!
2011 Traverse LT, 3.6L, FWD
Old 05-09-2016, 09:22 PM   #10
bikendan's Avatar
Generally:
Dry Camping is camping in developed campgrounds that don't have any hookups.
Boondocking is camping in areas that have no developed sites, such as deserts, BLM land, national or state forests, Walmart and so on.
This is how it's generally defined on most RV forums, that I've been on for the past 12 years.
Equalizer WDH
