Old 01-04-2019, 04:57 PM   #41
koller1509's Avatar
Originally Posted by Sounnder View Post
Good point but "containment" is needed, not confinement.
Just my useless .02 for this thread.
Yeah, brain is going faster then the fingers - Good Catch!!
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 01-04-2019, 11:26 PM   #42
Originally Posted by whjco View Post
Back on topic, for those of you who mount your generators on the rear of your trailer, how do you protect your generator when running it in rainy weather or protect it from the elements when in transit?
Thanks.
Bill J., Lexington, KY
I have a waterproof cover made for the generator and sold by Champion. I use it to cover the unit while in transit.
I salvaged some old canopy poles, shortened, and they hold a small tarp over it lean-to style. Right now bungee's hold it all in place but when I get back from this trip I'll Fab some pole sockets and fasten them to the platform. Poles will fit in place with tarp and generator will remain dry.
I've seen boxes with hinged sides that swing up on air intake end and exhaust end while running. Held down while in transit with suitcase hinges. Front only needs to be opened to plug in cord and start stop. A hatch on top to fill with fuel.
Limited only by imagination and skill.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 01-09-2019, 10:29 AM   #43
Brother in Law attached a diamond plate pick up bed storage box, the kind you see in the bed up to the cab, to the back of his Jayco. He used steel supports bolted to the two frame rails of the TT and support the box on the steel rails. He than through bolted the bottom of the diamond box adding wood block, 2x4's maybe, from the inside. Alot of room to securely carry his genset and gas cans. When doesn't need to bring them along it makes for a great storage box which occasionally he'll fill with firewood. Looks real sharp on the back of his rig. If it wasn't in storage I'd try to get a pic of his set up.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 01-09-2019, 10:54 AM   #44
robbiels7's Avatar
Kinda like this. I keep (gas can) for the generator in it also.Click image for larger version
robbiels7 is offline   Reply With Quote
Old 01-09-2019, 12:18 PM   #45
Robbiels, yep, looks pretty much like yours. And I thought my BIL was so smart!
Old 01-09-2019, 01:24 PM   #46
robbiels7's Avatar
I cant take credit I bought it like that. It actually holds the fuel tank for our generator. It has frame supports and holds 26 gallons for gas. We can run that thing forever on a full tank.
Old 01-14-2019, 08:55 PM   #47
I've always tried to keep my generator (Honda 2000i) dry - is that not an issue?
bobpalin is offline   Reply With Quote
Old 01-18-2019, 02:48 PM   #48
Front Gen Stand
Bought this stand for my Campion 3000 and then got a seasonal campsite. Go figure. I can strap it down and I have the cover for it when traveling.
harleyfltri is offline   Reply With Quote
truck
