Old 03-15-2014, 05:04 PM   #11
Originally Posted by fonzie View Post
You might have to take off the front face of the panel to see those fuses. Also how are you hook up to shore power: to a 50 amp RV receptacle or to a 30 amp RV receptacle with 30 to 50 amp adapter or to a 15 amp receptacle with what kind of adapter. Also if using adapters, are these all store bought or home made. Lots of questions but.....
30 amp service with a adapter from 50 to 30 got from dealer
paulmelissalauran is offline   Reply With Quote
Old 03-15-2014, 05:06 PM   #12
TURBS's Avatar
Originally Posted by paulmelissalauran View Post
Mine does not have those fuses.Attachment 47783
Yes you may have to remove cover.
TURBS
Sabre owners united!
Old 03-15-2014, 05:10 PM   #13
fonzie's Avatar
Last question for shore supply: are both AC working? this will check if you have power in your trailer to both side of the electrical panel. It will tell me if your 30 to 50 amp adapter is OK.
Fonzie
Old 03-15-2014, 05:11 PM   #14
Removed cover no fuses the only thing I have is the 15 amp breaker
Old 03-15-2014, 05:13 PM   #15
Only have 1 ac for this unit it's prewired for the second
Old 03-15-2014, 05:19 PM   #16
fonzie's Avatar
Last thing I can proposed is to see if all appliances work: micro-wave, refrigerator, outlets, water heater to see if again both side of electrical panel are supplied properly from shore power. After that you would need to use a multi-meter and start troubleshooting circuits if you are comfortable with it or get an RV tech or bring back to dealer.
Fonzie
Old 03-15-2014, 05:37 PM   #17
TURBS's Avatar
What is the model of your converter?
TURBS
Old 03-15-2014, 05:55 PM   #18
caper's Avatar
Are you positive that the 120volt side of the trailer is working? If the 120 volt side is working try resetting all the breakers. If this does not work you most likely have a bad 12 volt converter. You had 12 volts when first hooked up because you had a fully charged battery. When the battery lost its charge you lost 12 volt.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-15-2014, 06:09 PM   #19
TV works
Old 03-15-2014, 06:19 PM   #20
caper's Avatar
My guess would be that you are not getting power to the converter because of the adapter.
Terry and Janet
2007 Ford F150
12 volt, converter
