03-15-2014, 04:05 PM
12 volt converter
Just this past Tuesday took delivery of a 345 bh. plugged the unit up and been in and out of it for last several days. The only thing that works in the camper is 110 service no 12 volt service works. Called the dealer and the service guy is confused on this any help would be greatly appreciated.
p.s. no breakers are tripped
03-15-2014, 04:09 PM
do you have a 12 volts disconnect switch? In brochure it mentions of 12 volt disconnect switch as standard equipment.
Chaparral LITE & MID
Mandatory Package Includes:
Laminated and Aluminum Framed Floor and Sidewalls with
AZDEL • 15" Aluminum Rims • 16" Aluminum Rims (345BHS,
360IBL) Radial Tires • Dexter E-Z Lube Axles • Spare Tire • Pack
Max Storage • Universal Docking Station • 12 Volt Battery
Disconnect • Black Tank Flush • Steel Ball-Bearing Full Extension
Drawer Guides • Residential 60" x 80" Queen Bed with Serta
Mattress • AM/FM/CD/DVD Player with iPod Hook-up • Electric
Awning • Roof Ladder • Hitch Cover • Hide-a-Bed Sofa • Night
Shades • Exterior Speakers • Electric Front Jacks • 13,500 BTU
Ducted Air Conditioning • Swivel Rockers (where applicable)
• Cable TV Hook-up • Polar Package (Manufactured for Cold
Weather Camping with a Fully Enclosed Underbelly with
Heated and Enclosed Dump Valves and Astro-Foil Thermal
Insulation in Slide-out Floors and Bath Decks) • Dry Camping
Package (Built with High Quality 12 Volt Components Including
Stereo, Lighting and Slide-outs for Dry Camp Compatibility) •
Turn-Tec Engineering (combines an aggressive frame and cap
design to achieve the industry’s best turning radius by a
short bed truck)
Fonzie
03-15-2014, 04:25 PM
It does and it was on. I plugged the camper up Tuesday evening and everything 12 volts was working fine. Lights, radio.
03-15-2014, 04:27 PM
Just make sure it is pulled out if you have this type. Sometimes these get pushed in without knowing.
Fonzie
03-15-2014, 04:28 PM
It is the turn type located near the battery
Even if the disconnect is in the off position the converter should still power up 12v items in the camper.
A) the converter breaker is tripped or off.
B) the converter protection fuses are blown.
C) the converter has an issue.
The four fuses on the left are for the converter.
TURBS
Sabre owners united!
03-15-2014, 04:29 PM
TURBS
X2
Fonzie
03-15-2014, 04:30 PM
Ok will go check the fuses
03-15-2014, 04:45 PM
Mine does not have those fuses.
03-15-2014, 04:58 PM
You might have to take off the front face of the panel to see those fuses. Also how are you hook up to shore power: to a 50 amp RV receptacle or to a 30 amp RV receptacle with 30 to 50 amp adapter or to a 15 amp receptacle with what kind of adapter. Also if using adapters, are these all store bought or home made. Lots of questions but.....
Fonzie
03-15-2014, 05:04 PM
30 amp service with a adapter from 50 to 30 got from dealer
03-15-2014, 05:06 PM
Originally Posted by paulmelissalauran
Yes you may have to remove cover.
TURBS
03-15-2014, 05:10 PM
Last question for shore supply: are both AC working? this will check if you have power in your trailer to both side of the electrical panel. It will tell me if your 30 to 50 amp adapter is OK.
Fonzie
03-15-2014, 05:11 PM
Removed cover no fuses the only thing I have is the 15 amp breaker
03-15-2014, 05:13 PM
Only have 1 ac for this unit it's prewired for the second
03-15-2014, 05:19 PM
Last thing I can proposed is to see if all appliances work: micro-wave, refrigerator, outlets, water heater to see if again both side of electrical panel are supplied properly from shore power. After that you would need to use a multi-meter and start troubleshooting circuits if you are comfortable with it or get an RV tech or bring back to dealer.
Fonzie
03-15-2014, 05:37 PM
What is the model of your converter?
TURBS
03-15-2014, 05:55 PM
Are you positive that the 120volt side of the trailer is working? If the 120 volt side is working try resetting all the breakers. If this does not work you most likely have a bad 12 volt converter. You had 12 volts when first hooked up because you had a fully charged battery. When the battery lost its charge you lost 12 volt.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
03-15-2014, 06:09 PM
TV works
03-15-2014, 06:19 PM
My guess would be that you are not getting power to the converter because of the adapter.
Terry and Janet
2007 Ford F150
