Old 03-15-2014, 04:05 PM   #1
12 volt converter
Just this past Tuesday took delivery of a 345 bh. plugged the unit up and been in and out of it for last several days. The only thing that works in the camper is 110 service no 12 volt service works. Called the dealer and the service guy is confused on this any help would be greatly appreciated.
p.s. no breakers are tripped
paulmelissalauran is offline   Reply With Quote
Old 03-15-2014, 04:09 PM   #2
fonzie's Avatar
do you have a 12 volts disconnect switch? In brochure it mentions of 12 volt disconnect switch as standard equipment.
Chaparral LITE & MID
Mandatory Package Includes:
Laminated and Aluminum Framed Floor and Sidewalls with
AZDEL • 15" Aluminum Rims • 16" Aluminum Rims (345BHS,
360IBL) Radial Tires • Dexter E-Z Lube Axles • Spare Tire • Pack
Max Storage • Universal Docking Station • 12 Volt Battery
Disconnect
• Black Tank Flush • Steel Ball-Bearing Full Extension
Drawer Guides • Residential 60" x 80" Queen Bed with Serta
Mattress • AM/FM/CD/DVD Player with iPod Hook-up • Electric
Awning • Roof Ladder • Hitch Cover • Hide-a-Bed Sofa • Night
Shades • Exterior Speakers • Electric Front Jacks • 13,500 BTU
Ducted Air Conditioning • Swivel Rockers (where applicable)
• Cable TV Hook-up • Polar Package (Manufactured for Cold
Weather Camping with a Fully Enclosed Underbelly with
Heated and Enclosed Dump Valves and Astro-Foil Thermal
Insulation in Slide-out Floors and Bath Decks) • Dry Camping
Package (Built with High Quality 12 Volt Components Including
Stereo, Lighting and Slide-outs for Dry Camp Compatibility) •
Turn-Tec Engineering (combines an aggressive frame and cap
design to achieve the industry’s best turning radius by a
short bed truck)
Fonzie
Old 03-15-2014, 04:25 PM   #3
It does and it was on. I plugged the camper up Tuesday evening and everything 12 volts was working fine. Lights, radio.
Old 03-15-2014, 04:27 PM   #4
fonzie's Avatar
Just make sure it is pulled out if you have this type. Sometimes these get pushed in without knowing.
Name:	push-pull battery disconnect.jpg
Fonzie
Old 03-15-2014, 04:28 PM   #5
It is the turn type located near the battery
Old 03-15-2014, 04:28 PM   #6
TURBS's Avatar
Even if the disconnect is in the off position the converter should still power up 12v items in the camper.
A) the converter breaker is tripped or off.
B) the converter protection fuses are blown.
C) the converter has an issue.
The four fuses on the left are for the converter.
TURBS
Sabre owners united!
Old 03-15-2014, 04:29 PM   #7
fonzie's Avatar
TURBS
X2
Fonzie
Old 03-15-2014, 04:30 PM   #8
Ok will go check the fuses
Old 03-15-2014, 04:45 PM   #9
Mine does not have those fuses.Click image for larger version
Name:	ImageUploadedByForest River Forums1394919832.814685.jpg
Old 03-15-2014, 04:58 PM   #10
fonzie's Avatar
You might have to take off the front face of the panel to see those fuses. Also how are you hook up to shore power: to a 50 amp RV receptacle or to a 30 amp RV receptacle with 30 to 50 amp adapter or to a 15 amp receptacle with what kind of adapter. Also if using adapters, are these all store bought or home made. Lots of questions but.....
Fonzie
12 volt, converter
