Old 03-09-2012, 11:49 PM   #1
12v Water Pump vibrates bad when water is on...
12v Water Pump vibrates bad when water is on...is this normal? It rattles (shakes) so much you can feel it in the floor when the water is turned on.
ChiefGeek is offline   Reply With Quote
Old 03-10-2012, 04:09 AM   #2
Witch Doctor's Avatar
That is not normal, where is it mounted or located, is it a Shurflo ?
Old 03-10-2012, 06:47 AM   #3
Wanna Be Camper
SaskCampers's Avatar
Sounds like it is not fastened down properly. Find it and get an old mouse pad to put under it and then fasten it down. It is amazing how much noise disappears with a cheap old mouse pad.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 03-10-2012, 07:00 AM   #4
Triguy's Avatar
x2 on the mouse pad idea. Anything to soak up those vibrations. I also tied down and padded the lines where I could. That helped a lot.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-10-2012, 09:10 AM   #5
Mountainmanbob's Avatar
you'll get used to it in time
once you check
so as to make sure it is tight ??
let's me know
if it is runing sometimes for no reason
should not come on in the middle of the night
if no one is using water
pointing to
bad check valve
or
slow leak somewhere
MM
Mountainmanbob is offline   Reply With Quote
Old 03-10-2012, 09:29 AM   #6
Originally Posted by Mountainmanbob View Post
once you check
let's me know
pointing to
bad check valve
or
slow leak somewhere
MM
Good advice Mountainbod - that is why I always use the fresh water holding tank.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 03-10-2012, 01:36 PM   #7
bikendan's Avatar
most of the time, it the water lines vibrating against wood, that makes so much noise.
you can buy a Shurflo silencing kit or look to see what is making the noise.
mine was the lines vibrating against the wood cabinet they were in.
moving them away and wrapping them in some rags, eliminated almost all the noise.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
12 Volt
