Greetings,
I have a one year old 17BH that I pulled out of the RV storage (external lot) the other day. I filled the water tank about a quarter full and ran most of it through the faucets. I then attached city water and ran some more water through. I was basically making sure the pump worked and that there were no leaks after a winter sitting idle.
I found no leaks inside but did find a leak under the very rear of the right hand side of the trailer (almost under the bumper). I feared I had a leak in either the toilet and shower water hoses. I pulled the side off the shower and got a good look at the hoses. Everything is very dry.
My question here is: Is there a chance this could be from the water system or do I have a leak on the roof. It hasn't rained in weeks but I think the water may have been collecting above the plastic on the bottom of the trailer.
Any opinions?
I've included a picture of the leak. It was dripping off the bolt in the image and when I cut the plastic a little poured out there.
Thanks so much.
