Old 02-24-2017, 12:27 AM   #21
17FQ
We just traded a Jay Flight SLX 145rb for a "bigger" Viking 17FQ. No problems with the Jayco, but it was too small, even for two. For the three extra feet of length, we get: a walkaround queen bed, a dinette that we do not have to disassemble and reassemble every day to sleep, a full size bathroom with sink and vanity, full sized tanks for everything, 14" tires, more storage space. . .
The Viking also had little touches that were missing from the Jayco for cost cutting. I looked closely at the Clipper/Viking trailers a few years ago, but the 2017 has a new frame and larger wheels that I like even better now.
Homersimpson is offline   Reply With Quote
Old 02-24-2017, 11:00 AM   #22
WNY_Clipper's Avatar
At this time our Clipper is in storage, so I don't access to mine. Could someone possibly measure the sink opening for me on their 17fq? I want to build a cover for it, but I don't have access to mine to get the measurements. Could I get the inside opening and outside rim dimensions?
2018 Cedar Creek Hathaway Edition 36CK2
2015 Keystone Bullet Premier 26RBPR
2017 Chevy Silverado LT Z71
WNY_Clipper is offline   Reply With Quote
Old 02-24-2017, 11:37 AM   #23
cdog7201
Send a message via AIM to cdog7201
Homer I think you will really like the 17ft and it has a lot of storage we up graded from a popup. Just do a good PDI before taking it off the dealers lot . I pull mine with a jeep liberty a 2012 model. pulls great.
cdog7201 is offline   Reply With Quote
Old 02-24-2017, 11:39 AM   #24
cdog7201
WNY CLIPPER I will measure for you but give me a day or so I am busy for rite now.
Old 02-24-2017, 12:01 PM   #25
Thank you!
Old 02-24-2017, 01:33 PM   #26
I just saw the layout for the Clipper 17FQS! I may have gone this route if it was an option when we bought our 17FQ. Gives that extra dinette space I would have liked to have.
Old 02-24-2017, 04:49 PM   #27
cdog7201
cdog to clipper measurments
I just PMED you the measurements' you wanted let me know if you get it or not
Old 02-24-2017, 08:09 PM   #28
got it, thank you!
Old 02-24-2017, 10:10 PM   #29
cdog7201
glad to help I made a cutting board that fits over the cooktop and can be used for extra prep space. I thought it would come in handy. was easier to make then a sink cover I don't have a router just some saws and mechanical tools. I am not really a wood worker although my Dad and brother were carpenters. good luck in what you do.
Old 02-26-2017, 05:34 PM   #30
Did you look at what that slide does to the already meager cargo capacity?
17FQ - 749lbs.
17FQS - 408lbs.
2014 Coachman Clipper 17FQ
2011 Ford Ranger 4X4
Kenrod is offline   Reply With Quote
Old 02-26-2017, 07:06 PM   #31
17FQ - 749lbs.
17FQS - 408lbs.
Wow, I didn't notice that. Good catch!
Old 02-26-2017, 11:17 PM   #32
I noticed that when I looked at the specks. Holy cow Just filling the fresh water tank eats up 264 pounds so you're down to a meager 144 lbs!
Plus I wonder how far into the center isle the slide out sits when it's closed up. No quick stops to use the bathroom while in travel mode.
Barry, MSgt, USAF, Ret. & Rose
2017 Ford F150 w/ 3.5 EB
2014 Coachmen Viking 17FQ
Colorful Colorado
La Plata View is offline   Reply With Quote
Old 02-27-2017, 05:35 AM   #33
I was thinking the same thing!
Old 02-27-2017, 07:30 AM   #34
I didn't even consider the 17 FQS when I saw the numbers. The slide adds pounds and costs $ and all you get is a bigger dinette and some walking space. In a trailer this small, a slide is more trouble than necessary. Just brought home our 17 FQ and are happy with our decision.
2017 Coachmen Viking 17FQ
2006 Chevy Colorado Z71
Old 02-27-2017, 12:17 PM   #35
cdog7201
17fq
I weighed every thing I added to our 17fq last year after we brought it home not Including a full tank of water and came up with 460 lbs .If I remember we are allowed about 730 lbs. add 30 gals of water about 250 lbs and your at 700.lbs and that is not adding a lot of stuff.I bet most travel trailers are over loaded.
Old 03-01-2017, 12:18 AM   #36
I see tow vehicles where the front wheels are nearly off the ground all the time. Overloaded or incorrectly balanced.
At night their headlights are "spotlighting" low flying aircraft!
Colorful Colorado
Old 03-01-2017, 10:47 AM   #37
cdog7201
Yes Laplata I have seen this also that's why I insisted on having a WDH put on my jeep .The dealer said you don't need it I said I won't buy it with out it and there was no more argument .This thing pulls like a dream even 20mph side wind gust didn't push me around . when I had my popup that weighed 2000.lbs it would sway a little if I didn't get the weight distributed just right.SO I believe in the WDH even on smaller trailers money well spent.
Old 03-04-2017, 01:28 AM   #38
The Shower Rod looks like it would give a lot more room in the shower, but with the top kicking out like that, how do you keep the bottom of your shower curtain in the floor pan?
We replaced the stock shower curtain with a regular size curtain. The length is more than enough to stay inside the shower pan. Might still cut the curtain shorter but we will wait a bit for that. Don't cut anything until you actually try it out.
clearn4 is offline   Reply With Quote
Old 03-04-2017, 01:29 AM   #39
We actually are stepping on the bottom of the curtain buts that's ok to me considering the extra body room.
Old 03-08-2017, 07:40 PM   #40
Another quick tip. The wardrobe closets on either side of the queen bed are very narrow at the top and won't fit regular size hangars. Had me stumped until I saw child size hangars at the store. They fit just fine and hold our adult size clothes just fine. This is for the 17 FQ.
