Old 08-09-2019, 10:42 PM   #1
...Daveís not here.
203 RBK Slide Controller sensor
Does anyone know if there is any kind of level sensor in the controller interface itself?
I ask because I found it inside a very large unused space under my converter mounted to the floor.
My thought is to remove it and build a small opening cabinet in the side wall facing the slide so it can be;
1- accessed for service, calibration, reset
2- open up a very large space where I intend to place two additional batteries.
Relocating it will place it in a vertical alignment rather than the horizontal position it is in now.
I ask since the TT needs to be level before operating the slide if there may be a sensor for if you are wildly unleveled it will prohibit movement.
Scotch2cubes is offline   Reply With Quote
controller, slide
