Old 07-06-2012, 09:21 PM   #1
28dds bunk weights
Just wondering if anyone knows what the bottom double bunk is rated for weight wise? I think the top is rated for 150 lbs , I think !
2012 coachman catalina 28DDS
2006 F150 supper crew 4x4
Kevin Plant
North Bay ONT CANADA
spud7378 is offline   Reply With Quote
Old 07-06-2012, 09:29 PM   #2
Rsgtivr6's Avatar
Our top bunk is 200 lbs. It says it right on it on a little sticker. As far as the bottom, I would imagine with it being center supported and 1/4 plywood sheets, at least 3-400 lbs That one does not have a posting, though
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 07-14-2012, 05:59 PM   #3
ryand's Avatar
I have a 28dds.....love it by the way. There was no sticker on it indicating the weight but I am a heathy 240 and have slept up there without incident. Lots of the bunks I have seen at shows indicate 300lb max. I had a buddy sleep there for 3 drunken nights that was at least 200lbs also without incident. I would be interested in what Coachmen had to say about it.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 07-16-2012, 06:16 PM   #4
Just be careful. Make sure that the bunk actually lines up with the side rails. Mine does not line up and was bought that way. So there will be some factory warranty work going on shortly.
2012 Coachmen Catalina Deluxe Edition 28DDS
2002 Cadillac Escalade
St1tcher is offline   Reply With Quote
Old 07-28-2012, 05:46 PM   #5
Thanks for the all the input so what i did was put some supports from the floor under the side rails and put a centre support in as well I'm a healthily 260lbs and it held up great with no movement, the top bunk that's a different story I'm not even going to try that!
Kevin Plant
