Old 04-30-2013, 12:30 AM   #1
291qbs help
I have a 2013 291qbs and I notest that the axles are offset a bit. The front one sits more to the patio side than the rear. I called the dealer and he said that its part of the wide track design. I can't find anyting online about offset axles.
jayjos is offline   Reply With Quote
Old 04-30-2013, 03:55 AM   #2
crunchman12001's Avatar
Hi,
Can you take some pictures of your concerns so everyone can see what you are trying to explain?
crunchman
2015 F-250 FX4
Old 04-30-2013, 09:24 AM   #3
Old 04-30-2013, 05:41 PM   #4
Wow, that is not right at all. Is the other side rear tire inset like that too or does it stick out further that the front tire? Like the axle is shifted over or does it look like they used one long and one short axle?
Can you post a pic of the other side too?
Either way, I have never seen that before. Maybe some others will chime in but my guess is the TT should have never passed inspection at the factory or the dealer.
Did you point that out during your PDI?
crunchman
2015 F-250 FX4
Old 04-30-2013, 11:04 PM   #5
Its like It's shifted over. I purchased it from General RV in MI and had it shipped to my home in WA so I didn't inspect it. As soon as I get the paperwork to license it I'm taking it to a dealer near me. Somthing like that should be covered.
Old 05-01-2013, 03:54 AM   #6
Yes, it should be covered without a doubt. Make sure the spring shackle " U " bolts that connect to the axle are tight. I have heard those do come loose. Maybe the bolts are loose and the axle slide over? Be careful to inspect before towing it.
Anyone have any other ideas?
crunchman
2015 F-250 FX4
Old 05-01-2013, 08:58 AM   #7
daydreaming about camping
jeeplj8's Avatar
Can you post a picture of the other side as well?
That is definitely not right. If it were me, I am not sure I would pull it any distance at all until I got under there are looked for signs something is loose.
The axles are bolted to the springs with u-shaped bolts. If loose, the axle could do lots of weird things. Among those is twist or rotate forward or aft, which may damage your brake wires and mess up the alingment.
Really the only way to fix it is to drop the axle off the springs, align it and tighten it back up. This is not really a complicated job, but you would need a strong enough hydraulic jack to lift the trailer and then sufficient jackstands underneath to hold it up.
Rather than go to a FR dealer, I might suggest you contact FR about using a local trailer repair shop. I know my local trailer repair shop knows much more about the axles and running gear than any FR dealer I have seen. After all, that is all they do.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 05-01-2013, 10:12 AM   #8
I will try to post a pic of the other side later today.
Old 05-01-2013, 03:52 PM   #9
Its parked to close to the house to get a good pic of the other side right now.
Old 05-01-2013, 06:52 PM   #10
jayjos,
Not sure how handy you are regarding RV repair? Not an issue but everyone has their comfort levels.
When you get a chance, can you check the nuts on the U bolts to make sure they are tight? You really need to do that prior to towing it anywhere.
If you are not sure which bolts we are talking about, I can take a pic for you?
Keep us posted.
crunchman
2015 F-250 FX4
