Old 11-28-2013, 05:21 PM   #11
Professional Curmudgeon
There is an adjustment screw on the end of your pump, if the pump is cycling rapidly, increase the setting by turning the screw clockwise 11⁄2 turns
maximum, until the pump operates for 1 second, with at least 2 seconds of ‘off time’.
If adjusting the setting screw doesn't work, consider installing an accumulator after the pump.
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
Reese dual cam SC/WDH
wrvond is offline   Reply With Quote
Old 12-27-2013, 03:16 PM   #12
Scubanut's Avatar
I had same problem with leaf springs on my trailer being flat. It was so bad that when I was winterizing I was under the trailer I noticed that my tires were rubbing at some point on the floor of the trailer and was rubbing a hole in the plywood. I took the trailer into a truck suspension shop before I stored it. They swapped out the springs to a thicker spring. I noticed a difference right away, there not flat now. I will have to see once I'm fully loaded if it makes a difference on the ride. IE, will things rattle off the walls inside.
Cost was about $600 but if it saves further damage it is worth it.
Scubanut is offline   Reply With Quote
