Old 10-27-2013, 07:10 PM   #1
steeleshark2's Avatar
292BHDS Springs
Well, I think mine are going flat. I got underneath and it looks like I have PR-4b made by EMCO which are suppose to be made for up to 3500lb axles. I got info from Etrailer.com and they said the PR-4s from Redline will fit with a higher capacity (up to a 4800lb axle). Anyone else that has a 292BHDS, if you would not mind looking underneath at the spring for the tab I took a pic of to see if they have the same spring. I would appreciate it. I am seriously thinking about changing them out. I am curious if the weight in the trailer with people, water ect is stretching these things out while camping? Here are a couple pics:
ID:	41900   Click image for larger version
steeleshark2 is offline   Reply With Quote
Old 10-27-2013, 07:22 PM   #2
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
I wonder if one of the leafs are broken causing the spring to flatten out like that???
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 10-27-2013, 07:28 PM   #3
Ford Idaho's Avatar
If one is then OP should be able to see a huge rust red spot on one side of the spring pack.
Old 10-27-2013, 07:37 PM   #4
All four of the springs are this flat and I am not overweight verified by the scales. I have found many people with this trailer that have the same issue.
Old 10-30-2013, 11:54 AM   #5
I had this problem on mine as well. Verified by the dealer that they where indeed flat and he wouldn't let me pull it without fixing it. It took pics and CAT scale verification and Coachmen stepped up and paid for it. IF I hadn't provided the scale numbers they where going to reject the claim as they told my dealer I was probably overweight.
2012 Coachmen Freedom Express 292BHDS
2009 Ford F250 Super Duty CC 6.8L 4.10
Husky Centreline WDH w/Sway Control
2013 Nights Booked: 38
2013 Nights Camped: 40
pwrplay is offline   Reply With Quote
Old 01-04-2014, 04:17 PM   #6
1atalbot's Avatar
Hmmm, I just picked a new 292BHDS and will keep an eye on my leaf springs, I am hoping with all the buzz they improved them. Although, I did crawl under and confirm they're Lippert 3,500 axels.
1atalbot is offline   Reply With Quote
Old 01-09-2014, 10:49 PM   #7
Ft W crew's Avatar
Replaced my springs. I am currently communicating with Lippert to see if they will help with cost. Shipped them back to factory for testing. They claim I was overload but had a weight ticket stating otherwise (7450 lbs) with gear and water.
Less than $400 installed at dealership including cost of springs. I also went ahead and went with the 2000lb springs. I now have approx 3-4 inches above the tires to bottom of trailer. Dealership is less than a mile away so I have not be able to tell a towing difference yet but mechanic said it should be a lot less sway if I had any. I also replaced the china bomb tires with khumos d rated and that made a huge difference.
2012 Freedom Express Liberty Edition 292BHDS
2011 GMC Yukon XL 2500 4X4 (what a difference)
2007 Ford Expedition EL Eddie Bauer 2WD (sold)
Ft W crew is offline   Reply With Quote
Old 01-12-2014, 08:17 AM   #8
1atalbot's Avatar
I've written Coachmen on this matter and shared these links, I am wondering if they are even aware they have an issue with Lippert on the 292's I will keep a close eye on my "Leaf Springs"
I checked Lipperts site and the parts with shipping the 2,000lb springs is only around $130.00 so it's not a major expense.
Old 01-12-2014, 07:53 PM   #9
Scubanut's Avatar
I had the same issue with my springs. It was so bad the tires were striking the floor of the trailer and was rubbing a hole in the floor. Lucky I caught it and had a experience truck suspension shop replace them. I'm surprised the tires didn't blow as a result, I was hearing others were having similar problems. I had it done in Canada for under $600 taxes in.
Scubanut is offline   Reply With Quote
292bhds
