Old 10-19-2018, 02:23 PM   #1
jdshep
381RD Winterizing
Hello All,
My first post on here, but I have learned a good bit from you all. I just bought a 2018 Chaparral 381RD a few months ago. I've had several TT's in the past. This rig is different. The water intake and waste water control panel is convenient but new to me.
I might be using the camper once or twice this winter, so chose to use air and blowout everything instead of filling all the lines with antifreeze. Think I have it all figured out EXCEPT: How do I drain the fresh water tank and winterize the water pump? The only drains I see underneath are apparently the low point for hot and cold lines. Can't find a drain for the fresh water tank...
Any advice or knowledge you can give me is MOST appreciated.
jdshep is offline   Reply With Quote
Old 10-20-2018, 08:38 PM   #2
jdshep
Well, I found the fresh water tank drain. Right above the rear axle.
Anyone have any thoughts on winterizing the water pump?
Thank you!
Old 10-22-2018, 07:18 PM   #3
jdshep
I take it back. you guys haven't been much help. not one single comment about winterizing the water pump?!
Old 10-23-2018, 07:08 PM   #4
Lol
farmboy6180 is offline   Reply With Quote
Old 10-23-2018, 07:41 PM   #5
my unit has a pick up tube/stray right at the docking station. you can put it right into a jug of anti freeze and it goes straight to the pump.
Kimber45 is offline   Reply With Quote
Old 10-24-2018, 05:32 AM   #6
What if you don't do the antifreeze way and you only do the air method that's what he's asking and I have the same question
Old 10-24-2018, 08:27 AM   #7
Blow air into the pickup tube instead.
Iwritecode is offline   Reply With Quote
Old 10-24-2018, 08:29 AM   #8
Pickup tube?
Old 10-27-2018, 05:30 PM   #9
Don't forget to do the lines for the washer and dryer prep. I just about missed that my first time winterizing my 360ibl.
T1545jh is offline   Reply With Quote
Old 10-27-2018, 06:13 PM   #10
jdshep
Oh wow! Yeah I forgot those. Never had those before.
Thank you!!!!
winter
