Old 04-30-2014, 09:20 PM   #1
Wanna be Sir Campsalot
K4RGD's Avatar
A/C in your face
I gotta know. Anyone figured out a good way to keep the A/C From blowing in your face all night? In the Clipper 17FQ, no matter how we seem to adjust the vents, the design of the camper funnels the windstorm right on top of us, leading to dry throats and potential sniffles.
I'm thinking some command hooks on the ceiling and hanging a cloth across the vent to temper the airflow.
Anyone with any thoughts?
Rockwood Freedom 1640LTD / 97 Chevy Silverado 1500
Wildwood 26TBSS / 09 GMC Sierra 1500
K4RGD is offline   Reply With Quote
Old 05-01-2014, 01:35 PM   #2
wingedone's Avatar
I have seen people use plain old cardboard, cut and formed and then attached near the vents to divert air. You just don't want to restrict the air, that could cause it to freeze up. I am sure you could come up with something like that, only that would look better. Maybe, detachable.
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
wingedone is offline   Reply With Quote
Old 05-01-2014, 01:41 PM   #3
We can rotate ours and adjust the vanes.
Old 05-01-2014, 03:39 PM   #4
K4RGD's Avatar
We were able to shut off the vent on our old Dometic in the popup, but this Coleman eve. Rotating the vent 90 degrees upward leaves a slot across the bottom.
Better that than freeze up the unit, I guess.
Curtains might be my best bet.
Old 07-04-2014, 08:34 PM   #5
K4RGD's Avatar
Follow-up:
The curtain worked like a champ. We got two clear command hooks and a long lightweight curtain rod to span the distance from the upper cabinets on both walls.
We need something (another curtain rod, probably) to weigh down the flapping from the A/C blowing the curtain up, but...
No sniffles this go around!!!
Old 07-04-2014, 08:49 PM   #6
NELA
Weezer's Avatar
My first thought was to sew a hem/pocket across the bottom of the curtain and put ball bearings in it, keeping them spaced out by sewing vertical seams every 2 inches or so in the hem/pocket.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
