Old 11-27-2018, 10:05 PM   #1
A different AC Fan and Furnace Question
I've seen people ask similar questions, but this is kind of the opposite of the normal AC fan question. I like the AC fan running when the propane furnace is running (I like the steady noise when sleeping). In previous RVs I've had thermostats where setting the fan to auto makes this possible. However, in our 2018 Chaparrel 360 IBL, with the standard thermostat and controller I can't run the AC fan while the furnace is running on gas heat. Does anyone have a fix? I'm pretty sure I cannot just replace only the thermostat. The workaround is to use ceramic heaters and the fireplace and running the AC fan in fan only mode.
SRWNH is offline   Reply With Quote
Old 11-27-2018, 10:10 PM   #2
Mr. Dan's Avatar
Set the Fan speed to HI or LO. Setting it to AU (Auto) keeps the A/C fan from running with the furnace.
Click on this ==> #4.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 11-27-2018, 11:00 PM   #3
Thanks. I should have been clearer. What I'm trying to say is that I have cool, heat and off modes in this system. There is no stand alone fan mode like other thermostats that I have had and I don't seem to have the option to set the fan to auto when in heat mode. I can access an auto fan setting while in the cool mode, but it gets cleared when I switch to the heat mode to turn the furnace on. I also looked through the furnace control board manual and there is no dip switch that I can find that would enable it either. I guess the ultimate question is whether or not the control board and thermostat can or should be swapped out.
Old 11-28-2018, 11:10 AM   #4
Head Rambler
Can you tell us which brand and model thermostat you have?
It may also help if you could post a picture of it.
Gotta go campin!
Old 11-28-2018, 11:21 AM   #5
I've seen this accomplished using two thermostats.
My buddy did this by replacing the Coleman Mach analog thermostat with a digital one and then separated the furnace control wires and used the analog thermostat for the furnace only.
I would also believe (again for those units using Coleman A/C units) that a switch could be wired at the thermostat to run the A/C fan only.
I'm guessing a switch from the red 12v+ wire to either the green or grey fan wires would do the trick.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 11-28-2018, 12:03 PM   #6
Attached is a photo of the thermostat, an RVComfort.ZC. Also attached is the listing of possible thermostat modes from the owner's manual. You can see that the fan can be energized without the AC running in cool mode. The heat mode is either nothing operational or gas heat energized, but nowhere can the fan be energized. Makes no sense to me why the fan cannot be used in heat mode for circulation.
edit: The fan CAN be energized when using the heat strip, and needs to be, but not when using gas.
Name:	Thermostat functions.JPG
ID:	192297   Click image for larger version
Old 11-28-2018, 02:52 PM   #7
Yes, like that
5Picker has it right--has given you almost all the information you need. Find the manual or installation guide for the thermostat. As he showed, it will have a list of terminal numbers and/or wire colors and what they do.
What you need to do is
  • Add a wall mount switch like this one next to the thermostat.
  • Dismount the thermostat from the wall, so it's hanging by the wires
  • Cut a piece of wire about 2 feet long
  • Connect one end of the wire to the +12 terminal on the thermostat
  • Connect the other end of the wire to the Fan High or Fan Low terminal on the thermostat
  • Poke the end of the looped wire into the wall
  • Make a hole, maybe 3/4" in diameter in the wall. You will mount the new switch over this hole
  • Reach into the hole with a stiff hooked wire. Hook the looped wire and pull it out of the hole
  • Cut the loop and connect each of the ends to a terminal on the switch
  • Mount the switch to the wall
Larry
Larry-NC is offline   Reply With Quote
Old 11-28-2018, 03:28 PM   #8
I also have a 360ibl. I understand your frustration with the fan issues as it is one of my biggest complaints with this model. My other 2 gripes would be the fact that the temp sensor for "zone 2" is in the hallway as well as the bedroom light switch. So, if your door is closed you can't turn the lights on or off and it's extremely hard to regulate the bedroom temperature. I have already relocated the light switch and temperature sensor into the bedroom. As far as the AC fan goes, my plan was to mount a white switch on the AC cover above the bed that will turn just the fan on. I have not looked at the wiring yet, but I'm sure it's possible to tie into the wires coming from the thermostat and "jumper" the fan on.
T1545jh is offline   Reply With Quote
Old 11-28-2018, 03:36 PM   #9
Head Rambler
Larry
It's going to be a little different than this because this particular thermostat uses digital communication to the A/C and there are no wires for the fan. However, There are individual wires for the heat functions, so you could use a separate heat only thermostat for the furnace and then set the RVComfort.ZC thermostat to fan only. You need to go into the programming to figure out which heat source the furnace is wired as (heat 1 or heat 2).
Gotta go campin!
Old 11-28-2018, 09:12 PM   #10
WATCHING: Another happy 360IBL owner who's wife is interested any solutions.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
fan, furnace
