Old 02-28-2019, 04:59 PM   #1
AC runs 24/7, PITA!
Why do rv acs have to run all the time. Why can't the fans cycle on and off like the compressors?
Lee Pedrick is offline   Reply With Quote
Old 02-28-2019, 05:04 PM   #2
fonzie's Avatar
make sure thermostat fan is set to "auto" mode instead of fan "on"
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 02-28-2019, 05:11 PM   #3
cavie's Avatar
x's 2. put the fan in AUTO. just like at home. that is if you have A/C at home.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 02-28-2019, 05:27 PM   #4
bikendan's Avatar
Very common issue.
Should have a thermostat manual, that will have instructions.
If not, download one.
As was said, you probably have set on HI or LOW fan setting.
Should be on AU.
Equalizer WDH
Old 02-28-2019, 07:07 PM   #5
It is always set on auto. Hi/Lo fan does nothing. So you guys are saying the fan should cycle on and off as the compressor does? Just like My home AC does?
Old 02-28-2019, 07:15 PM   #6
Usually Confused Member
emm-dee's Avatar
Yes.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 03-01-2019, 12:17 AM   #7
cavie's Avatar
x's 2
Old 03-01-2019, 12:21 AM   #8
Fulltime family RVer
Yes, with the fan on Auto, it should cycle.
With the fan set to Hi or Low, it'll stay on 24/7.
Make sure you're not mixing the "auto" setting which decides if it should turn on heat or A/C depending on temperature with the actual fan setting.
Old 03-01-2019, 12:34 AM   #9
On most travel trailer rooftop units, the fan does run all the time. I can't remember the wording in our manual, but it has something to do with air circulation. It is definitely annoying. Our mini MH has the same type of unit and it gets turned off when not needed and the windows opened.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 03-01-2019, 12:39 AM   #10
cavie's Avatar
Not so. It happen mostly with the newer Heat Pump units. But they too will cycle on and off if one learns how to use the t-stat.
