Old 06-12-2016, 10:36 AM   #11
Ford Idaho's Avatar
Originally Posted by Dooger54 View Post
As I said in the original post- current vent is not wired.
How far is the nearest light from the vent?
If you have more than one light on a single switch do the lights have individual rocker type switches on them?
Old 06-12-2016, 12:47 PM   #12
The closest light with a rocker switch is over our bed, about 5 feet away. Hard part will be trying to snake a wire to that light. It is a very small light, will a base of probably only 1-2" diameter.
2017 Coachmen Freedom Express 254DSX
2016 F150 4X4 Ecoboost Lariat SuperCrew
Dooger54 is offline   Reply With Quote
Old 06-12-2016, 03:14 PM   #13
Ford Idaho's Avatar
I see, this does make it harder but not impossible.
It all depends on how much you want the vent.
Is having it done for you out of the question?
Old 06-13-2016, 11:10 AM   #14
I looked more closely at how I might get 12v wiring to the vent this weekend. Nothing easy for sure. Not sure I want the powered vent that bad.
I wouldn't rule out having it done for me, but I have done a fair amount of wiring, snaking wires in my day - and no matter who does this, it won't be an easy job.
So I am inclined to forget it at this point.
Old 06-13-2016, 03:03 PM   #15
Ford Idaho's Avatar
I understand completely had the dealer install the Maxx Air in the lite.
Dropped it off after work picked it up after work the next day, had them put the original vent and parts in a box so I could hang on to it.
Old 06-13-2016, 03:36 PM   #16
flymhi's Avatar
Dooger54 - I had the same issue with my unit. I changed out both the bedroom vent and bathroom vent to fantastic fans and am very pleased. The front bedroom vent was not powered and there was a separate 12V light that was independent of wall switched mushroom lights. I used a coat hanger and fished wire the 3' distance to the independent light. Just be careful and try not to displace the roof insulation as you fish the wire.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
Old 06-13-2016, 08:00 PM   #17
Dooger54
I also picked up a 2016 254DSX and first thought was after we picked it up is.
I have to put a Fantastic Fan over this bed.
I haven't tackeled that project yet but when I do I will tap into the nearest main LED light.
The ones that are hooked up to the main switch when you walk in.
I don't think it will be a problem those lights draw such a low current that I'm not worried of overloading the circuit.
I'll make sure that we switch off the fan from the switch up top otherwise it'll come on every time we come into the trailer and turn the lights on.
As far as installation, a friend of mine told me. Just take your time, no short cuts and do it right and you'll have NO leaks.
1996alnl is offline   Reply With Quote
Old 06-13-2016, 08:48 PM   #18
Originally Posted by 1996alnl View Post
Dooger54
The problem with hooking into the led lights on the main switch is that the fan will only be on when the lights are on. So if you want to run the fan during the night when you sleep, you'll be sleeping with the lights on.
Old 06-14-2016, 02:23 AM   #19
Ah yes. Your right, I never thought of that.
I will have to fish a wire from the closest light.
One of the reading lights I guess.
Old 06-14-2016, 06:27 AM   #20
Your right it is a small opening..but with patience it's possible.
freedom express, power, vent
