Old 09-09-2015, 12:06 PM   #1
Adding air to Nitrogen filled tires (292BHDS)
My Coachmen Freedom Express 292BHDS came from the dealership with nitrogen fliled tires.
If they get low, can I add regular air to them? Or do i have to find someplace that can add Nitrogen? What are my options?
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 Coachmen Freedom Express 292BHDS -- SOLD
2013 RAM 2500 CTD
2018 Prime Time Crusader 319RKT
Loraura is offline   Reply With Quote
Old 09-09-2015, 12:10 PM   #2
I add air to mine. The nitrogen, I believe has a larger molecule size and is not supposed to leak as readily. I also believe that nitrogen is less affected by temperature. We used it to pressure test air conditioning system before the first fill if we were using a hand made lineset.
Filthy Beast is offline   Reply With Quote
Old 09-09-2015, 12:36 PM   #3
Air is 78% nitrogen so no issue to put air in a nitrogen tire.
And now I will sit back a watch this thread explode into an AIR vs Nitrogen debate.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 09-09-2015, 12:37 PM   #4
karrun's Avatar
I recommend Argon.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 09-09-2015, 12:38 PM   #5
I think I'll get a glass of tea & join you Happy Vibe; this is going to be fun.
Papa GLS is offline   Reply With Quote
Old 09-09-2015, 12:43 PM   #6
DaveSchwartz's Avatar
Here goes the can of worms again...
General consensus is that its (mostly) of no benefit so don't worry that you can't find it when you really need to increase inflation. True that its not supposed to permeate out through the rubber as fast due to the larger molecule but air is 78% nitrogen too. If you're not checking pressures before every pull, you're living on borrowed time anyway no matter what you use. Any interior degradation due to oxygen in air is negligible and you've got to replace your tires long before that could possibly be an issue - they'll rot due to the air/UV on the outside long before (ozone is the biggest enemy of rubber).
The benefit to you in the A/C trade is probably that it is dry (very low moisture-carrying capability) so you're not contaminating a system right off the bat.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-09-2015, 12:44 PM   #7
Originally Posted by karrun View Post
I recommend Argon.
Krypton for me... keeps Superman away too! Only use noble gases - not those common ones!
Old 09-09-2015, 12:45 PM   #8
EastlakeRoo's Avatar
Just put regular Air in it and move on. Wouldn't make a project out of filling up tires to proper air pressure.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 09-09-2015, 12:54 PM   #9
That shouldn't be a project, it should be a religion!
Old 09-09-2015, 12:55 PM   #10
Thanks all!
It seemed that it would be ridiculous if I COULDN'T just add regular air, but this nitrogen thing is new to me, so I wasn't positive!
It's been parked since the end of July, and we're taking it on a trip in 2 weeks, so I wanted to make sure I could top off the tires if needed.
2013 RAM 2500 CTD
Old 09-09-2015, 12:56 PM   #11
karrun's Avatar
Xenon? Has the added benefit of glowing pretty colors if you electrify it too.
2016 Roo 21SS
Mods so far:
Old 09-09-2015, 12:56 PM   #12
Set pressure with whatever compressor you have handy and get out and enjoy!
Old 09-09-2015, 12:58 PM   #13
Helium... will reduce the unsprung weight and keep the weight police at bay!
Old 09-09-2015, 04:03 PM   #14
(Dry Huunday)
DreiHunde's Avatar
Pass the popcorn please!!
DreiHunde is offline   Reply With Quote
Old 09-09-2015, 04:15 PM   #15
Director, FROG
F.R.O.G.'s Avatar
You could use nitrous oxide. You get the best of both elements, and have the added benefit of hearing your tires laugh as you drive.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 09-09-2015, 04:20 PM   #16
schrederman's Avatar
Aw.... now that's just mean..... Funny as all get out... ...but mean.....
I LIKE IT!!!!
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 09-09-2015, 04:32 PM   #17
Why don't we just foam fill them( like wheel barrow tires) and never have to worry about filling again.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 09-09-2015, 06:40 PM   #18
I prefer acetylene, if you run out of fire starters just pop the valve stem and POOF!! You've got instant heat!
AJ Kirkpatrick
2003 Dodge Crew 3500 Cummins
2015 Coachmen 320BHDS Liberty Edition
AJCR2011 is offline   Reply With Quote
Old 09-09-2015, 08:35 PM   #19
Knew this would be fun!
Old 09-09-2015, 08:42 PM   #20
Iwannacamp's Avatar
My old GF(long story) worked with a guy who was simple. He did janitorial work at a bank. Each time he got gas...he added air...just in case. One day a worker at the station said...are you sure you need air? Did you check it? He said...naw I just add some in case. They checked the tires and he had like 80 psi in 70's ford 1/2 ton.
2017 Puma 297RLSS
292bhds, led, tire, tires
