Old 05-03-2016, 05:37 AM   #1
shorthorn's Avatar
Adding small fridge to basement storage
Hey yall.... looking to add a small dorm fridge to the basement storage area on our 360ibl.... I know I seen a post on here about doing that before, but can't for the life me me find it again.
Wondering if anyone whom has done this can give me a pic and help with how you secured it in place.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
Old 05-03-2016, 05:51 AM   #2
hrlyguy2's Avatar
Not sure on your trailer .But I have one in my Sandpiper
Got it from Walmart .Had to put it on a angle to get it in but works perfect
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 05-03-2016, 06:29 AM   #3
Insert witty title here
Any fridge you get will only work when connected to shore power so using it as cold storage while traveling won't work unless you load it up with ice like a cooler.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
timfromma is offline   Reply With Quote
Old 05-03-2016, 07:28 AM   #4
shorthorn's Avatar
Tim... I realize the shore power restraint ... unless I add an inverter. No matter... you get it cold at home pre trip loaded with drinks and as long as it's kept closed, it will stay cold for many hours... our fridge / freezer at home will keep food cold enough thru an 8 hour power outtage, I figure the beer will be cold enough after 2 to 4 hours.
Old 05-03-2016, 08:36 AM   #5
Sign me up and colour me curious as well, as I too recall this mod from the past but would also like to make this work.
kitestiff is offline   Reply With Quote
Old 05-03-2016, 09:19 AM   #6
My trailer came with a second fridge already installed. I pack it with ice and use it like a cooler when not hooked up to shore power.
Old 05-03-2016, 11:38 AM   #7
jason_sos's Avatar
My trailer has one, as does my friends. They are secured with the metal banding that is typically used for duct work - comes in rolls with holes every inch or so. They just ran it through parts on the bottom of the fridge and screwed it to the countertop.
2016 Coachmen Freedom Express 282BHDS
2008 Dodge Ram 1500 Quad Cab 4x4 Big Horn, 5.7L HEMI
jason_sos is offline   Reply With Quote
Old 05-03-2016, 12:08 PM   #8
I saved the piece of Styrofoam that came in the bottom of the carton....Fridge sits on that in front storage of our 5er.Never moves!!....Wired an "AC" box marked "12 Volt Inverter" to the inverter and battery.....Use this in transit......When we arrive on site at CG I plug the cord into the 120 volt AC Box......
Jim in Halifax is offline   Reply With Quote
Old 05-03-2016, 12:42 PM   #9
Kaadk's Avatar
Wouldn't it have been easier to wire the single plug to a switch so you can just select between the inverter or shore power?
Kaadk is offline   Reply With Quote
Old 05-05-2016, 09:32 PM   #10
farmncamp's Avatar
Here's a small dorm fridge I added to the front of my 360IBL. I used 2x 2x4 wood to keep it from smashing the outlet in transit (one top one bottom). I added a big inverter near the battery and ran an outlet right under the 120v outlet. This way I can power the fridge while driving or boondocking.
Occasionally I'll run the camper power cord and plug into the inverter. Obviously you'd want to disable things like the converter, fridge, ac, microwave, etc but its a good way to power outlets when boondocking.
2015 Coachman Chaparral 360IBL
2012 6.7L Ford F350 SRW
53 nights camped in 2017.
farmncamp is offline   Reply With Quote
Old 05-06-2016, 04:10 AM   #11
shorthorn's Avatar
Thanks buddy!
fridge, storage
