Old 10-18-2018, 04:38 PM   #1
Advanced electrical question
A friend of mine who owns a similar RV (28 RKS) which is equipped with a 30 amp service and a power management system "Claims" he upgraded his cord to a 50 amp and added a standard 110V-15 amp plug in-line with the 30 amp service plug. When camping, he plugs both the 30amp plug and the 110v- 15amp plug into the pedestal. He indicated he can then bring 45 amps into the rig with no problems? I do basic electricity but this is above my head. Would this not effect the power management device? Is there an additional 15 amps available at the pedestal? I can see how this can be considered fraudulent when only paying for 30 amp and I do not intend to do this, however, I wondered if this is possible? The other consideration I though would be "back feeding" 30 amps into a 15amp outlet? Thank you as always for your input.
jsj248 is offline   Reply With Quote
Old 10-18-2018, 04:53 PM   #2
llr
he had to do more then change the cord as the 50AMP cord has 2 hots and it sounds like he is connecting one hot to the 30 and one to the 15.
What is he doing with the 15 on the camper end? He could be running a separate circuit to dedicated outlet / device. There is no place for the 2nd hot in a 30amp panel.
as to if the pedestal has 45 amps available, maybe and it could very by campground and even site within a campground. If he trips a feed breaker in the middle of the night he could have no power for awhile.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 10-18-2018, 04:54 PM   #3
western NC mountains!
formerFR's Avatar
you concerns are o.k., but I doubt that the outcome he was looking for is the reality of what he is really getting, power wise. He probably doesn't even understand that true '50amp rv service' is a double-pole 240v incoming power with two hot legs at 50amps each... his thought is probably that it is 'only' 50amp total power, instead of 100 amps.
He could have accomplished the same thing by simply purchasing a 50amp to 30/20 adapter, that allows you to plug a 50amp shore cord into both a 30amp and a 20amp outlet at the same time, giving a max of 45-50amps... and NO, there's absolutely nothing wrong with that - no campground or rv park limits your usage of 'which' outlets you plug into, how many at the same time, or whether you use any at all. They are there for your pleasure.
Now, if he 'really' upgraded his whole coach to be a '50amp coach', then he would have had to both change out his 30amp shore cord to a 50amp variety, AND, upgrade his Main Electric panel to a 50amp 'split' service panel(100amps total), AND his ATS(automatic transfer switch) to a 50amp model. Likely that's not what he did. He simply changed the END of his shore power cord to provide both a 30amp male end, and a 15/20amp male end(like a more typical extension cord end).
Even if he is bringing in more than his 30amp Main Panel breaker is designed for, it's likely that he did, or could, change out that main breaker for a 45 or 50amp breaker, giving full ability to use all amps without tripping the main breaker in the coach.
Many of us use varied methods and options when it comes to getting more 'power' when we need it. As long as it's safe, it doesn't really matter that it's done, as long as it give you the power you are wanting. While many will quote codes and electrical requirements, they are usually referring to homes, not RVs... they are not regulated the same, and when you do your own work, it doesn't fall under any obligation anyway.
When my 50amp coach is in the heat of the summer, and I am at a 30amp campground, I bring out my same 50a to 30/20 adapter and make use of as much power as I can get, since I am 'limited' to what my RV might normally need. If I can use two different 30amp outlets in the park, I have an adapter to do that too, giving me up to 60amps of power. Sometimes, even with 50amp full service, I make use of the additional 20amp outlet at the power pole and use an extension cord to bring in those amps to the coach, for additional fans or heaters, when it's especially hot or cold outside.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 200w/10amps mobile SOLAR
85,000+mi, US, Alaska, Canada, western NC for now : )
formerFR is offline   Reply With Quote
Old 10-18-2018, 07:16 PM   #4
That explains a lot. Increasing the inward amps will probably create havoc with the power management system, not to mention overloading the 30amp incoming breaker. I guess the best solution if additional amps are really needed is to simply tap the 110 outlet via extension cord (amp rated) and power the additional appliances (heater/fan/??) off the extension cord instead of trying to increase the amps on the current 30 amp system? At least, that was my humble thought when he suggested I do the same. So far, I simply do not need that much amperage in the smaller rig I have.
Old 10-18-2018, 08:29 PM   #5
Head Rambler
I'd really like to see how he modified the cord. If it's how I suspect then there's some danger if he ever runs into a pedestal that has the 30 amp receptacle and the convenience receptacle tied to different phases, then he'll have a dead short between the 30 amp and the convenience receptacle. If he's lucky, all that will happen is that the breaker(s) will trip.
Gotta go campin!
Old 10-19-2018, 09:25 AM   #6
Reply to Bama
After talking with him, he said he ties the two hot leads together in the 5o amp cord. Being a fireman I asked if he was concerned about potentially feeding 30amps back into a 110amp circuit and he indicated it would simply trip the 110v breaker. I don't have enough knowledge if an electrical breaker is directional or omni-directional. If it's omni-directional, I would thing that the 110v would kick as soon as it senced the 30amp hookup? On the other hand, if it depends upon the amp draw, I assume the combined 30+15 would cover at least a true 45 amp draw? Again, I do residential electricity and I have never run into a double amp feed system. Thanks BAMA.
Old 10-19-2018, 09:39 AM   #7
AquaMan's Avatar
The only way I can see this as even possible, is if he plugs into 50amp service and uses one leg to feed his 30 amp box and one leg to fed his 15amp (utility). Tying the 2 50amp legs together will blow the breaker instantly.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
AquaMan is online now   Reply With Quote
Old 10-19-2018, 09:45 AM   #8
cavie's Avatar
You can not use the 30/20 dogbone adapter mentioned above in most campgrounds. The 20 amp outlet in most campgrounds is GFI protected. You trailer/coach as a GFI circuit inside. 2 GFI circuits in series don't play nice. One of them will trip. You can run a separate 20 extension from the ped to your rig to power whatever 20 amps you want as long as your not going thru your electric converter.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 10-19-2018, 09:53 AM   #9
formerFR's Avatar
Exclamation
Originally Posted by [B
AquaMan[/B];1953565]The only way I can see this as even possible, is if he plugs into 50amp service and uses one leg to feed his 30 amp box and one leg to fed his 15amp (utility). Tying the 2 50amp legs together will blow the breaker instantly.
he said that "When camping, he plugs both the 30amp plug and the 110v- 15amp plug into the pedestal."... this means he is NOT plugging into a 50amp outlet, only plugging into both a 30 AND a 15/20...
and
cavie "You can not use the 30/20 dogbone adapter mentioned above in most campgrounds."
he's not using an adapter, he basically took the pedestal end of a 50amp shore cord and 'adapted' it with both a 30amp male plug and a 15/20amp male plug, to use BOTH outlets... similar, but different... this may not 'trip' the GFCI like manufactured adapters do, but who knows. If it works for him, I guess it's working for him : / though he's only seeing up to 50amps this way, not the true 100amps for 'true' 50amp RV service, since he's only pulling 30 from one side, and up to 20 from the other.... but, it's still better than only 30 : )
Old 10-19-2018, 09:54 AM   #10
llr
tying the 2 hots together has a number of issues. if one of the plugs are not plugged in you have an electrocution hazard with the exposed prongs being hot.
Also as mentioned above if he ever uses a pedestal with split phases he will have a direct short on the 220V feed. If he plugs in with the breakers on expect massive sparks, burnt plugs & outlets.
And if he did nothing to the camper there is no advantage as it still has a 30A main breaker. Lots of negatives for little if any benefit.
The only possible benefit I see is if the campground has a week 30A breaker which they sgould replace instead of working around it.
electric, electrical
