Old 04-02-2016, 10:22 PM   #1
Apex 258 RKS
This is our first travel trailer, only had it out one time which we enjoyed. We have one problem which is hardly any heat coming through bedroom vent. Anyone have the Apex 258RKS with this problem or any other problems with this unit?
28 ft travel trailer
2012 Ram Larime 2500 5.7 hemi
Vimax is offline   Reply With Quote
Old 04-07-2016, 08:04 AM   #2
chaztrewhitt's Avatar
Could have some collapsed insulation, or something else in there. Or the duct may have come loose from vent. You could run a wire puller or similar through duct and see if you feel blockage. Another trick I have done is pull the vent and stick a leaf blower in there. We do not use the gas heat unless absolutely necessary. $$$ We use two space heaters, running off the campground power system. Our 279 RLSS blows like a hurricane! And just about as loud!
chaztrewhitt is offline   Reply With Quote
Old 04-09-2016, 08:08 PM   #3
I feel a little air coming out of vent and was told that the duct might be collasped alittle under shower floor. I will continue trouble shooting and with some of your suggestions as well. Thxs for the input.
