Old 06-03-2015, 02:45 PM   #1
Apex 259bhss paper towel holder
So I want to mount a paper towel under the microwave. Without having to pull it out has anyone already looked under there to see what clerances are like? Looks like 4 screws hold the microwave in and I'm feeling lazy and don't want to remove it. I'll need to install anchors as it's going into some thin luan panelling. Here's a picture of where I'd like to mount it.
pontiacgta2002 is offline   Reply With Quote
Old 06-03-2015, 03:04 PM   #2
There will be a gap between the panel you want to mount the holder to and the floor that the microwave sits on. It will be deep enough for that plug to fit in, around a couple inches would be my guess.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-03-2015, 03:11 PM   #3
Yeah true on that. I was thinking when I was taking the picture to remove the outlet and take a look see. Since I typed all that up then the picture I decided to fire it off and see what responses I get. Since I'm doing this from the phone app. Thanks!
Old 06-03-2015, 03:16 PM   #4
I installed the same paper towel holder on the side of my cabinet. I did not use any plugs and it has held for 2 years including a 100 miles down a logging road.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 06-03-2015, 04:03 PM   #5
Nice. Well all installed now. Just screwed it up there without the anchor. Also installed this simple latch to keep this cupboard open instead of using my head.
ID:	78945   Click image for larger version
Old 06-03-2015, 04:03 PM   #6
Stand on your head to see the bottom picture Lol or rotate your monitor.
Old 06-04-2015, 06:26 AM   #7
I saw the second picture and thought if you can change gravity then you don't need to hold the door with your head.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 06-04-2015, 01:02 PM   #8
KAS
Originally I attached a paper towel holder to the inside of a cabinet door with stick-on foam tape, however it wasted too much cabinet space. Then I found the solution: a paper towel holder with strong magnets! I stuck it to the side of the range hood, where it is easily accessible, stays put, but can be removed when necessary. Perfect!
KAS is offline   Reply With Quote
Old 06-04-2015, 01:48 PM   #9
Nice idea
