Old 02-11-2016, 02:10 PM   #1
Apex 288 BHS TV reception
We just teased our 2013 Rockwood Roo on a 2016 Apex 288 BHS. We noticed the Apex does not have a extendable antenna. How is the reception and have you done anything to improve the reception in this model. So far, just sitting in the driveway, we really like the layout
Mike
Mikemiller69gs is offline   Reply With Quote
Old 02-11-2016, 02:32 PM   #2
Hey Mike, I JUST got the answer to this question this week. I have the 300bhs. This is what I was told by Major Malfunction on this forum "As for the TV antenna, there is a booster! If you look on the electrical outlet below the main TV where it plugs int, there is also the cable TV plug. On this face plate is a little black(?) button. Push that on and you will see a red light turn on. That's the signal booster. If you are using antenna TV, you want that in to get good quality reception. If you are on landline cable TV, you want this OFF. "
Hope this helps!
2016 Apex 300BHS
TV: 2005 Silverado Z71, 4x4 lowered and re-geared
ApexBunk is offline   Reply With Quote
Old 02-11-2016, 07:51 PM   #3
Thanks for the quick response. Our last two campers had a handle to rotate the antenna for fine tuning. That helped in spots where we have weak reception. Aside from the booster, anything to enhance the signal?
Old 02-11-2016, 08:20 PM   #4
UmptySquat's Avatar
I have a 288BHS and saw improvement with the booster. However, my reception died just before winterizing this year. I'll have to debug that in the spring...
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 02-12-2016, 12:52 PM   #5
ccsvolsfan's Avatar
Replace it. Omni antennas have a very short range, maybe 25 miles.
ccsvolsfan is offline   Reply With Quote
Old 02-12-2016, 10:39 PM   #6
Any suggestions on a good replacement ?
Old 02-16-2016, 09:18 PM   #7
KDHfan's Avatar
Subscribing. The antenna on these things are dreadful. But not really any worse than my previous Rockwood. Contemplating a Directv mobile unit... But that might be going a little too far, even for us glampers. 😂
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
reception, tv reception
