Originally Posted by Mikemiller69gs
I assume you use the air terminal? If so, I tried that and it didn't work. I'm guessing I have a connection issue somewhere
I am trying to remember because I am not near my camper. On the outside I think you should have a Cable and then a Sat connection. This is for the external source. You are connecting Cable from the RV site so use cable.
Inside: You should have a cable connection. Use that with the booster off.
The little circuit board you saw that should be on the inside of the camper is your booster/amp board for when you use the antenna on the roof.
Have you removed the plate for the external cable/sat connections on the outside of the camper? Maybe loose connection there???
2015 F150 3.5 EcoBoost Lariat FX4 502A 3.55 Gears Max Tow KO2 Tires
2017 Grand Design Imagine 2150 RB / Traded in Catalina 253RKS
