Old 11-13-2018, 10:53 AM   #1
Camper402's Avatar
Apex Nano 193BHS Water Pump
Can anyone advise where the water pump is on a Nano 193bhs. I believe it is under the lower bunk as I have already checked behind other access panels with no luck. Thanks in advance.
Camper402 is offline   Reply With Quote
Old 11-13-2018, 04:19 PM   #2
You are correct.
It's under the bottom bunk. There may have one or two screws holding the plywood down. Pop those out, and you'll have access.
I just left those out after that.
kfergiez is offline   Reply With Quote
Old 11-13-2018, 06:18 PM   #3
Camper402's Avatar
Thank you. I had my suspicions it was under there but wanted to check before I started taking more screws out.
pump, water, water pump
