04-08-2017, 07:08 AM
Apex water pump
Apex TT. Hooked up at campground. Shortly after water was leaking out of the fresh water fill connection. Is there a bypass or diaphragm in the water pump allowing city connected water to fill fresh water tank? THANKS
04-08-2017, 07:10 AM
Who Dares, Wins
There is a check valve in the city connector. If there is a screen on it remove it and use a screw driver or similar to gently push it in to release.
2015 Chevy HD D-Max
2022 Impression 315MB
04-08-2017, 07:11 AM
Who Dares, Wins
Disregard, though I read city connection..
2015 Chevy HD D-Max
04-08-2017, 07:12 AM
Who Dares, Wins
The pump itself acts as the check valve. Is your fill a gravity fill or a hose connection to fill the tank.
2015 Chevy HD D-Max
04-08-2017, 07:18 AM
Gravity fill for fresh water
04-08-2017, 07:25 AM
Who Dares, Wins
Ok the pump should be acting as the check valve. If it is dribbling out might be a bit of grit. Try disconnecting the city water, let the pump push water through the lines and see if it clears the leak. If not might need a check on the pump by taking the diaphragm off to see if it is faulty. Is this the first use of the trailer or just a new problem.
2015 Chevy HD D-Max
04-08-2017, 10:42 AM
All my sinks have good pressure except my bathroom sink. It's very low. I'm connected to city water.
ARMY Veteran
GO DAWGS!!!
How Bout them Cowboys!!
17' Coachmen Apex 300 BHS
15' Ram CC Laramie 4x4, 3.92
04-08-2017, 10:44 AM
Did you remove the faucet aerator and look for debris?
Sometimes the individual faucet cartridges get debris in them as well. I've even seen plastic shavings where the water lines attach to the faucet. You'll need to disassemble the faucet and inspect.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
04-08-2017, 10:49 AM
Thanks gonna go check now
ARMY Veteran
GO DAWGS!!!
04-08-2017, 11:18 AM
Gonna have to do this after this camping trip once I drain all the water
ARMY Veteran
GO DAWGS!!!
04-09-2017, 10:53 AM
You can just unscrew the aerator and check it. You won't get any water flow as long as the tap is turned off.
current TV-2016 F-150 3.5 Ecoboost Max Tow
current TT-2016 Apex 300BHS
Reese Dual Cam WDH
