Old 03-31-2016, 04:55 PM   #1
chaztrewhitt's Avatar
APEX Water Pump location
Need help locating waterpump and any possible bypass valves on APEX 279RLSS. I can hear it, sounds like it is under the sink area but not sure.
Thanks in advance.
chaztrewhitt is offline   Reply With Quote
Old 03-31-2016, 05:27 PM   #2
I have the same model. Not sure where fresh water pump is. The only bypass valves I've worked with are behind a panel at floor level to the left of the sink. A few screws hold in the panel. I've only used city water thus far in our first season with this model. Good luck.
martinto is offline   Reply With Quote
Old 03-31-2016, 05:44 PM   #3
Just anticipating issues and it's nice to know where this stuff is if there is an issue. I really never see us using a self contained unit, but, nice to have i guess.
thanks again!
Old 03-31-2016, 06:11 PM   #4
Apex
Perhaps you can let me know where you find the water pump. While we usually go for CG's with full hookups, we are thinking to take her cross country later this summer. We may need fresh water along the way. Est 4-6 weeks, but realize that after a couple of weeks, we may want to head back home! What do you pull with?
Old 03-31-2016, 08:53 PM   #5
Ill do it! I hate to reinvent the wheel if information is available, but, as an Engineer, Ill have this thing tore apart and schematics made of every system given a little time. (My radio is bad, due to shorts on external speakers, no big deal, I can survive without this). Knowing some wiring and plumbing info sure makes it more better when things go bad on a trip.
cat, location, pump, water, water pump
