First, you need to find out where the short circuit is. The fuse blew because a wire shorted somewhere. DO NOT!! put in larger fuses!! The size of the fuse is there to protect the size of the wire and the load on that circuit. A larger fuse might allow the wire to melt and cause a fire before the larger fuse blows. Guaranteed,, if that fuse blew,,,a wire shorted somewhere,,,and the most likely place is where the wires are disturbed or flexed at a common point like where they feed the awning. That would be where the awning joints are when it is opened or closed. Hope this helps.
