05-31-2018, 06:47 PM
Azdel Walls
No reply from Azdel yet. Does anyone know for sure, not opinion, how thick these walls are on a 2018 Chaparall? And what is the prescribed fastener for attaching accessories?
My dealer installed slide toppers are showing minor evidence of not being attached properly. (The wall end, not the slide end) Looks like they used minimum number of tiny sheet metal screws. My plan is to re-calk and then use proper length screws. Lots of them, like one ever 4in.
05-31-2018, 07:03 PM
You should contact the factory directly for a "for sure not opinion" answer if anyone knows they should.
Retired Navy
2016 Flagstaff 26 FKWS
05-31-2018, 07:08 PM
Open the door and look at the door jam and you will not only see the thickness, but the makeup.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
05-31-2018, 07:22 PM
You don't have to remove the door jam?
I emailed Azdel several days ago
05-31-2018, 07:45 PM
So far there's 3 of us who don't know the answer...
05-31-2018, 08:29 PM
The exterior sheeting is about 1/4 from looking at it. I cut a hole for the dryer vent in mine. The center is just foam insulation, so there is no value to long screws. On my unit if you look up under the slide out you can see where the exterior sheeting runs down past the floor. Have you looked under yours?
With that said my unit is a 2016. I have no clue if they change over the years.
06-02-2018, 08:34 AM
TT: '15 Freedom Express with Azdell walls. IF I remember correctly the "Azdell" is a plastic sheet that the exterior fiberglass wall is attached (glued?) to. This plastic sheet replaces the old thin wood sheet they used to use in order to cut down on overall weight and it does have some structural integrity. I cut out a piece when installing an electrical connection so that gave me a good look at the construction of the exterior wall. From the exterior: 1) The fiberglass outer sheet, 2) the Azdell sheet, which is quite thin, no more than 1/16", 3) styrofoam insulation, maybe 1"-1 1/16" thick, 4) then the interior wall panel which is thinner than what I know to be "luan" paneling, this panel is no more than 1/16". The overall thickness could not be more than 1 1/4" on a good day. That said, I have hung numerous items on the interior walls, nothing heavy. I always use one of the plastic anchors that spread out when the screw is placed into it. I have also tried the "Command" type hooks but do not want to bond to the interior walls very well. I think it is the fact that the interior walls have a texture to them. Now the shower walls--that's a different story. There are Command hooks in there for myself, my GF, and each of my three (3) g'son's to hang our wash clothes on. I have also added a couple of Command soap type dishes for soap and small bottles of shampoo.
06-02-2018, 08:36 AM
No
Look at the area where the strike plate is. On my unit I can see and measure the thickness of the individual layers and the total wall. I would not use 2" screws.
TST Tire Monitors
2 100W solar panels
06-02-2018, 07:03 PM
Cool, I'll take a look. Thanks everyone
06-02-2018, 08:10 PM
Top is what they used, most were stripped at install. Bottom is what I replaced them with, and I couldn't get them to strip. Much beefier. I'm happy again.
06-02-2018, 08:21 PM
I saw a interesting YouTube video on Azdel from Haylett Rv. You should be able to find by searching pretty easy
Dennis
Coatesville PA
Flagstaff 25FBLS
06-02-2018, 08:55 PM
https://youtu.be/0S86wb-yGEM
If I owned a dealership, I would want this guy leading my sales department
06-02-2018, 09:07 PM
Given that the "Azdel" part of these walls are made of recycled water bottles (guessing via Destert Storm/Shield and such) that it makes sense why the fine threaded tiny screws just stripped out while the beefier course threaded screws lock down and my screw gun could not get them to strip.
My greenhouse is made of recycled Desert Storm bottles, and it's tough as Schwartzkopf.
06-02-2018, 09:55 PM
Here is a nice video where a Coachmen representative take you on a factory tour of Azdel:
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
06-04-2018, 08:12 AM
(Dry Huunday)
agreed!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
06-04-2018, 08:19 AM
Gold Tee Box
There are some very good Utube and other videos about Azdel if you do a simple search.
If you are mounting on the inside of the walls, and not going through to the outside, you can use short wall anchors, or just use velcro strips. Just be careful not to go too deep.
I was considering a TV mount on the outside, and the information I found was to not puncture the outside at all.
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
