04-25-2017, 10:15 AM
Battery cut off switch
One of the things that I miss from our Rockwood RV is the battery cut off switch that was located next to the control panel.
I want to install one and it can be around the battery someplace since it would be a much easier install there. I assume that others may have put one on? If so, what switch did you use and where did you get it.
Thx
04-25-2017, 02:08 PM
Amazon $7.00
2016 Coachmen Apex 250RLS Ultra Light 2023 Ram 2500 Big Horn Sport 3.73
04-25-2017, 02:24 PM
Have you looked under your LP tanks in front of your battery? That's where most of them have been moving to.
2011 Traverse LT, 3.6L, FWD
04-25-2017, 05:48 PM
2018 Cedar Creek Hathaway Edition 36CK2
2015 Keystone Bullet Premier 26RBPR
2017 Chevy Silverado LT Z71
04-25-2017, 08:32 PM
Battery Drain installed battery disconnect switch
04-25-2017, 08:45 PM
Originally Posted by WNY_Clipper
I installed the same one with zip ties to the trailer frame. Works great.
04-25-2017, 09:04 PM
Here is a picture of it installed, along with a new lighting fuse block, and LED storage lighting.
04-26-2017, 12:42 PM
Thanks all. I've verified there's not one near the tanks anywhere. I have ordered a switch for installation.
04-26-2017, 01:54 PM
Too late if you ordered one already BUT I always use Perko switches. I've had them on my boats and RV's. Good quality at reasonable price.I installed 2 on my Cardinal. one for the batteries that is Off-1-2-Both and another for my converter that is just an on-off.
PERKO Inc.
Oh yea, they are all made in the good old USA
Good luck!
Bill
Bill
2016 Forest River 3250 Cardinal
2016 RAM 2500 Longhorn
Previously: 36' Country Coach
04-29-2017, 09:25 PM
disconnet switch
Are they installed on negative or positive cables?
04-29-2017, 09:35 PM
Perko recommends the positive side and that's what I do on both boats and my RVs.
They have some good diagrams on line and the switches come with instructions.
04-30-2017, 05:20 AM
When I researched switches before I bought and installed mine, I saw that many people switched the negative side. I guess that would work, but I decided to go old school and switch the positive side.
04-30-2017, 07:34 AM
Battery disconnect switch
The battery disconnect switch is wired on the negative terminal.
04-30-2017, 08:05 AM
Negative side is usually easier and safer to work with, but either side will work.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
04-30-2017, 08:22 AM
Whole point is that you are breaking continuity between positive and negative side. With a switch anything inside RV that uses battery will be disabled once either + or - is broken.
05-19-2017, 07:35 AM
SUCCESS!
We will return our RV to storage this afternoon after being in it for a week. When we picked it up earlier this week the battery was in fact dead. I don't know why they did not install a battery cut off switch. Yesterday I successfully installed the cut off switch like WNY clipper uses. Install was no big deal. The particular cable that I bought to extend it was black. And, by buying this cable I did not have to do any cutting on the cables themselves. Therefore I installed it on the negative side so that the colors would be consistent. I just didn't want to install a black cable on the positive side (red side) and then someone in the future to think because they saw a black cable that it was negative.
I used double back tape to stick it to the frame right in front of the battery box. I also used zip ties to hold the cables together. My thought was if the double back tape didn't hold well the switch itself still couldn't go anywhere.
05-19-2017, 02:45 PM
Congrats on your install of the battery disconnect switch!
I also installed a "BDS" on my unit too. Instead of mounting to the battery box, I mounted my switch to the frame next to the battery box. And I mounted mine on the negative side as well.
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
05-19-2017, 02:52 PM
Perko does that since boats do not have chassis grounds (well, except steel ones.)
2015 335DS
05-21-2017, 05:42 AM
This is the one I installed I had to get a bigger battery box but it fits perfectly and the battery will not slide around
2016 Coachmen Apex Ultra-lite 298bhs
2009 Chevy Avalanche
05-21-2017, 08:14 AM
Attachment 138580
That's the one I installed as well.....
Gerard
Blue Ox SwayPro WDH
