03-08-2015, 07:20 PM
Battery question
I went to dig my Viking 17BH out of the snow and ice at the storage lot in preparation for a trip to warmer climates.
An hour of shoveling and 2 bags of salt later I was able to get to the battery box and realized that I forgot how the battery was wired. I have a white wire and a black wire which is connected to a red wire and a 20 amp fuse.
Which is positive and which is negative? They aren't marked.
Thanks in advance for your help.
2013 Honda Ridgeline
2015 Coachmen Viking 17BH
03-08-2015, 07:37 PM
Black should be negative/ground.. red/white, positive.
03-08-2015, 07:54 PM
Can you meter to your disconnect switch easily? Turn the switch off, and meter continuity and that should have it.. Or to the resetable fuse ahead of it?
Camped: 2023 (Days/Nights) - 34/27
2022 (D/N) - 41/33, 2021 (D/N) - 37/29, 2020 (D/N): 58/49, 2019 (D/N):27/20
TT: 2020 26' Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
03-08-2015, 08:12 PM
You said your black was connected to the Red? Correct? The Red should be positive.
And usually, the fuse is on the positive, hot, side.
2012 Lacrosse, 308RES.
2013 Ford F150, XLT, 4x4, Supercrew, Eco-Boost.
Lee, Dawn and "CoCo", the dog!
2015 Overnight Camping Days = 25, States Below:
03-09-2015, 05:49 AM
From your statement " I have a white wire and a black wire which is connected to a red wire and a 20 amp fuse ".......The white wire would be negative (ground) and black wire would be positive.....post a picture if you can.
Also follow white wire and it should be connected to the frame of the trailer.
Fonzie
03-09-2015, 06:50 AM
As others have stated if you follow the white and it's connected to the
frame- that will be your negative lead.
Another way to be sure is to plug your trailer into your truck and use
a meter to test the white and black wire.
When the meter reads 12v PLUS the red meter lead is the positive trailer
wire.
Another way is to plug in the trailer to shore power and read voltage
across the battery leads. AS above- when you see a plus reading, the
meter red lead is on the positive trailer wire.
IF you have some red paint or red fingernail polish you can mark the plus
wire once you figure it out.
They make red electrical tape (which I have) and it's very handy to wrap
the plus wire and avoid any confusion from then on.
Peace!
Dan & Rita D
It is not unusual to see trailers wired to the colors used in buildings, Black HOT (+) and White Neutral (-).
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
03-09-2015, 03:33 PM
Be sure you test before you hook. Make dang sure. A co-worker fried his trailer hooking it up backwards.
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
03-09-2015, 03:43 PM
That's exactly how my travel trailer is.
You don't want to hook them up backwards, even for a sec. If so, you will most likely blow the reverse polarity fuse(s) to your converter.....then will be having to replace them.
These reverse polarity fuses can be in your fuse panel, or can be on the face of the converter itself.
2011 Flagstaff 831 RLBSS
03-09-2015, 03:46 PM
