Old 09-01-2019, 09:48 AM   #1
shorthorn's Avatar
Bedroom slide out floor rotted / water damage!
Hey guys...
Noticed as we were prepping for our labor day trip that the floor of our bedroom slide was wet underneath and the wood almost completely rotted away!
This is on a 2016 Coachman Chapparal 360IBL. This 5th wheel is stored indoors except that it is out in the summer between trips. I have been meticulous on caulking and sealing the roof...
Anyone have ideas what I could have missed. Nothing in the roof, sidewalls inside or out, or even the floor above the plywood is even damp.. or shows signs of ever being damp.
I do have extended warranty... has anyone had luck getting them to warranty water damage?
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
Old 09-01-2019, 10:35 AM   #2
SeaDog's Avatar
May be coming from the slide seals not sealing.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-01-2019, 04:20 PM   #3
shorthorn's Avatar
Thanks Seadog... come to think of it... I have probably not checked them over good enough...
Old 09-02-2019, 05:37 PM   #4
The bottom corners of my slide was not sealed and rain water was coming in during heavy rains. The dealer says it was supposed to be that way. They said they were weep holes in case there was a water pipe burst inside. Yet the same model on another lot had them sealed. I took pictures and showed my dealer and then they fixed it.
DExpy17 is offline   Reply With Quote
Old 09-02-2019, 08:51 PM   #5
I had the BR floor rotted in our 2016 Silverback. Did not even know it but when I took it to Orvan he found it. He said a lot of folks don’t keep up with the sealant that is along the decorative trim along the bottom on the outside of the slide. Check your sealant with the slide closed along the top edge of the border piece that goes along the bottom of the bedroom slide. You know, it creates the sharp corner you would cut your head open on if you did not put a pool noodle on it..
The reason it is neglected is it is out of sight. Can’t see the seam unless you are on a ladder.. worth a look.
2016 Siverback 33IK
Old 09-03-2019, 06:49 AM   #6
shorthorn's Avatar
I think you nailed it... I checked that seam out and there were a couple spots that were not sealed well... of all the places I have caulked and sealed this rig... i never thought about that trim piece... ugh.
Originally Posted by dalford View Post
I had the BR floor rotted in our 2016 Silverback. Did not even know it but when I took it to Orvan he found it. He said a lot of folks donít keep up with the sealant that is along the decorative trim along the bottom on the outside of the slide. Check your sealant with the slide closed along the top edge of the border piece that goes along the bottom of the bedroom slide. You know, it creates the sharp corner you would cut your head open on if you did not put a pool noodle on it..
The reason it is neglected is it is out of sight. Canít see the seam unless you are on a ladder.. worth a look.
Old 09-03-2019, 01:02 PM   #7
Unhappy
I have a Coachman Brookstone and found the same problem. Fortunately I caught it when it had only started to rot the first inch or so. Source of the leak is missing or bad sealant on the top edge of the bottom border piece (exactly as described in the quote). My bedroom slide has a slide topper, but that didnít help stop the rain that dripped down into the top edge of the border piece. A bad piece of work at the factory - and weíre stuck with the results.
2014 Coachmen Brookstone 325RL
2015 Chev Silverado 2500 Diesel.
ottawapaul is offline   Reply With Quote
Old 09-03-2019, 01:16 PM   #8
shorthorn's Avatar
Did you repair it yourself? Still trying to convince myself I can do this!
Old 09-03-2019, 01:19 PM   #9
slide out leak
As mentioned above I tried several different sealers on mine nothing worked, finally I put clear Gorilla tape on it so far so good
jjcook is offline   Reply With Quote
Old 09-03-2019, 02:02 PM   #10
Fixed it myself.
I had the same issue with about 8" of the floor damaged. I cut it back a foot. Then put 2x4 braces under the bed frame as far back as it would go. Then I attaced a new board to the braces. I used treated wood for all the repairs.
ID:	214129   Click image for larger version
ID:	214130   Click image for larger version
ID:	214131   Click image for larger version
ID:	214132   Click image for larger version
bobneal69 is offline   Reply With Quote
bed, bedroom slide, floor, roo, slide, slide out, water
