Old 11-12-2019, 12:51 PM   #1
Bent Rear axle
I have a 243rbs coachmen Catalina 2018 TT. The rear axle is bent. Only 2000 mi on it. only had it 1.5 yrs. Bought new. Anyhow, just went thru all the measurement BS with Lippert frames. It has Dexter axles which lippert put on their frame. They are telling me I have to go to Dexter axles for a possible fix. Of course this problem never shows up during the warranty period. So clue me in anyone on whats it going to be like to dead with Dexter. The dealer said they are backed up 3 months just to get it in while telling me its out of warranty.
TT: 2018 Coachmen Catalina
243rbs(rear bath) legacy edition
TV: 2017 Ram 1500
Lee Pedrick is offline   Reply With Quote
Old 11-12-2019, 12:55 PM   #2
Have you contacted Dexter directly?
I've not had a bent axle but have got great response from them in the past.
There are several reports here of them "overnighting" axles to those in emergency need. I don't think you'll get a run around from them.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 11-12-2019, 01:38 PM   #3
Fulltime family RVer
Dexter treated me well on a warranty vent fan replacement. Not an axle, I know but their warranty support was good.
ependydad is online now   Reply With Quote
Old 11-13-2019, 09:11 PM   #4
bent axle
Thanks Guys,, I'll be calling them tomorrow.
TV: 2017 Ram 1500
Old 11-13-2019, 10:54 PM   #5
NMWildcat's Avatar
Well, the good thing is that if Dexter doesn't warranty it, axles are fairly cheap. And if you can install it yourself, even better.
Just helped my buddy replace his axle after he hit a tall curb way too fast
Was actually a very easy job for two people.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 11-14-2019, 01:38 AM   #6
So...how is the axle bent? Are you getting abnormal tire wear?
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 11-14-2019, 10:17 AM   #7
bent axle
You can see where its bent. Caught my eye when I saw the tires wearing badly on the inside. I just sent all the info and pics to Dexter,,waiting to hear back.
TV: 2017 Ram 1500
Old 11-14-2019, 02:10 PM   #8
Can you post a few of the pics you sent the manufacturer? I would like to see how the axle is bent. Any idea of how it happened? Thank You.
olebull is offline   Reply With Quote
Old 11-14-2019, 02:44 PM   #9
Brother Les's Avatar
'ALL' (never good to say 'all') RV axles are 'bent'. Can you describe how it may have been 'bent' and where it is bent? Tire wear can happen for a number of reasons. ie. bad bearings, loose bearings or alignment issues or a loose tire.
All of these axles may 'look' bent.... because they are bent in the middle upward.
https://www.etrailer.com/dept-pg-Tra...-6000_lbs.aspx
Brother Les
Old 11-14-2019, 03:35 PM   #10
I know all about the normal bend in the axle and why its there. The axle is bent to the right of center upwards on the passenger side. Sending pics is like trying to do rubic's cube. LOL!! That tire is almost bald on the inside. Never hit anything,,,I think its been there since new.I always thought that wheel looked alittle off but heard, and read about people saying that is normal for a rear axle. Not even 2000 miles,,,all short 2hr trips.
TV: 2017 Ram 1500
Old 11-16-2019, 10:33 AM   #11
can someone clue me in on how to post pics. It asks me for a URL,, what is that?
TV: 2017 Ram 1500
Old 11-17-2019, 08:05 PM   #12
Head Rambler
Are you on a PC or a mobile device?
If it's a PC the easiest way I've found is when you're in a thread to go to the bottom of the thread and select "Go Advanced" at the bottom of the reply window. Then select the paper clip icon in the top row of icons. It will pop up a window where you select attachments (pics) and then once you've chosen the files (pics) you select upload and then you close the window. But you're not done yet. Once you're back at the relay window you select the down arrow beside the paper clip and that's where you can select the files to show in the reply. It's a little arcane compared to most forum software, but it's not too hard to get used to once you figure it out.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 11-17-2019, 08:37 PM   #13
Retired Old Fart
dward51's Avatar
Is the axle bent and one tire is out of alignment, or is that entire axle out of alignment to the frame? IF it's the latter, it may be the normal bend of the axle and it is just out of alignment (could be the hangers also). The fix for that is different.
Or is it if you lay a straight edge on the front or back of the axle, the axle tube is not straight (front/back, not top/bottom as that is supposed to be bent slightly).
Depending on where you live, there may be a commercial trailer shop nearby. They do axle repairs on commercial trailers all day long and will usually also work on travel trailers. It's an easy fix for them and their bread and butter job where a RV dealer may not be so well trained in bending an axle. Or like was previously pointed out, a replacement axle is not that expensive (assuming the hangers are not out of position).
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 11-17-2019, 08:55 PM   #14
Please post what Dexter does. I too have a bent axle..actually the kingpin. mine will not be a warranty issue but still needs to get fixed.
Mike134 is offline   Reply With Quote
Old 11-17-2019, 09:02 PM   #15
You have a bent what?
Old 11-17-2019, 10:08 PM   #16
KINGPIN
It's what the inner and outer wheel bearings roll on. Bright shiny machined steel pin that's welded to the end of the axle. I'm guessing the previous owner hit a curb hard and bent the pin upwards causing only that wheel to have a large negative camber. You might also call it the spindle depending on where your from.
Old 11-18-2019, 12:27 AM   #17
KINGPIN
Thanks for clarifying. I learn something new every day. Iíve heard it called a spindle but never a kingpin. The only kingpin I knew of was what connects fifth wheels to the truck and that didnít fit the topic at hand.
Old 11-18-2019, 01:05 AM   #18
It's not another name for a spindle.
This is what I always thought a kingpin was. It's the vertical shaft that allows the spindle assembly to pivot(steer) on certain types of suspensions.
Old 11-18-2019, 05:12 AM   #19
Maybe it's one of those horizontal or transverse kingpins?
Perhaps regionally specific terms? Around here if you ask for a starter solenoid you'll probably get the deer in the headlights look. You have to ask for a Bendix.
Its like ranch casing for around a door or window. Ask for that on the Eastern shore of MD and they'll say .....What? You have to ask for a piece of clamshell molding lol.
Feel Swift is offline   Reply With Quote
Old 11-18-2019, 07:36 AM   #20
Yes, let us know what Dexter does. They gave me great support on a Friday night and Saturday.
Wife and I discovered 2 broken wheel studs (same wheel) when crossing into Oklahoma. Luckily, at fuel stop next to a campground. Called Dexter at 4:55 PM Friday afternoon. Logistics Manager answered phone, only person there. He asked what I needed, axle serial numbers etc.. called me back about 15 minutes later and asked if I minded driving to his home Saturday morning. He was waiting with a cold drink, all the parts I needed, and no cost.
2018 Surveyor 264RKLE
Retired
Location depends on weather
Jeffjeeptj is offline   Reply With Quote
axle, bent
