Old 02-02-2019, 12:50 PM   #1
Best way to remove 4x8 coroplast?
I have 4 x 8 sheets of chloroplast and Am curious what is the best way to slide them backwards and remove them when there’s pipes sticking throughClick image for larger version
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 02-02-2019, 01:20 PM   #2
Are the pipe/hose pieces flexible enough that they can be pushed up into the hole AS the sheet is moved in one direction or another?
To reinstall merely push sheet in from other direction (if possible) so the bend of the pipe is not hooking into the sheet as it moves Once re-attached the pipes could be realigned with some heat from a hair dryer.
Also, is it possible to work the sheet to one side or another to allow it to be dropped below the "track/support"?
As a last resort one might just resort to cutting a piece of the material out to provide enough room to remove/cut off the pipe for clearance. When work is done and corroplast is replaced, splice the cut off pieces of pipe back in place with appropriate fittings and secure cut out piece with some sheet metal and screw patching.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 02-02-2019, 01:27 PM   #3
nomad297's Avatar
Push up on the Coroplast where the 1/2” PEX is protruding, slightly bend the PEX and slice through it with a sharp razor knife while you are bending it. When you are finished, put the PEX back together with SharkBite couplings.
Bruce
Old 02-02-2019, 01:57 PM   #4
The pex pipe is short and pretty rigid.
The shark bite alternative is appealing since I could remove it when necessary and reinstall it.
Also I was considering cutting a slot in the corroplast and resealing with scrimshield tape.
Old 02-02-2019, 02:20 PM   #5
And if all else fails, cut it out and replace it. Coroplast (corrugated plastic) is commonly used as a sign material and can be purchased at just about any sign supply company in 4×8 sheets. I've even seen it in 4x12 sheets. Also available in a variety of colors.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2/4.30
Equalizer E2 with single old-school friction sway control.
woo10-210 is offline   Reply With Quote
Old 02-03-2019, 03:05 PM   #6
Quick update on this— I was able to pull the chloroplast down in the middle and it easily came out from the sides.
Also noticed the rigid short pex run (low point fresh water tank drain) easily unscrewed from the tank.
Old 02-03-2019, 06:25 PM   #7
chaps2018, thanks for the follow up! Didn't know the fresh water drain could be that easily removed.
Dirt Sifter is offline   Reply With Quote
