04-20-2016, 07:58 AM
Black tank level issue
Hi all! We are enjoying our 2015 248RBS freedom express and use it quite a bit. The last few trips I've niticed that although i empty the tank completely, the black tank will still read 2/3 full. Any ideas on fixing the sensor or anything? Thanks, Peter in Florida
the BugCart
2015 Coachmen FE 248rbs, 2011 Ram 1500
Cannondale mountain bikes
Kayaks
Beautiful wife
04-20-2016, 08:08 AM
Do a Search in the box at top of this Page. Days/Weeks of reading on "Sensors"! Youroo!!
04-20-2016, 04:35 PM
At the moment, mine are reading correctly. I don't expect it to last too much longer. It's only been used once so far.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
04-20-2016, 05:22 PM
My sensors never worked from day 1 and haven't looked them in years. When there is water coming up in the shower the grey is full. I can hear a significant change in the noise made when flushing the toilet when the black is getting close.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
04-20-2016, 05:28 PM
Read other threads as suggested. The short answer is that your sensors (or sensor areas) are most likely covered with TP or waste due to inadequate flushing out of the black water tank. Just dumping it out won't "do" it, and most likely insufficient water was used when flushing the toilet during use. That tank needs lots of liquid.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
04-20-2016, 05:58 PM
We have tried a lot of "fixes", but they mostly fail. The only thing that works consistently is a black tank flush, which we have on this trailer.
If you don't have one, they can be installed, and it is usually not that difficult or expensive.
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
04-21-2016, 12:13 PM
Thanks all!
the BugCart
Kayaks
Beautiful wife
04-21-2016, 01:15 PM
Inaccurate sensor readings
Best thing to do is get your hands on some poop eating, sensor cleaning, nano bots. However, since they cost millions of dollars and are only available from the Department of Defense, I would probably go with plan "B"...which is to use the "GEO method". Information about it is available through this site or on the web. Good luck!
04-21-2016, 05:19 PM
I've had 5 class A MHs. None have had accurate readings all the times. I haven't had the newest one long enough to be able to tell. We only took it once for 5 days, and didn't have sewer hook up. Some days it showed 1/2, the next check was full, next check was 1/4 and on and on.
The MH I had before that was not accurate, until I used a liquid cleaner a couple of times. Then I always made sure I had plenty of water, and had around 3/4 full before I dumped, and flushed the tank. That seemed to help a lot.
04-21-2016, 05:45 PM
On your next trip, empty the black tank, dump a gallon of SuperClean in the toilet and about 5 gal of water and drive home. When you get home, finish filling with clean water and let set for at least 24 hrs and then drain. Would also help to drive around with a full tank before emptying.
04-21-2016, 06:50 PM
5 - 10 pounds of ice cubes and a good black tank cleaner just before a road trip should help clean the sensors.
DJsFolly
