Old 08-11-2015, 05:44 PM   #11
Nick M's Avatar
Brookstone tanks
My 2010 Brookstone 360RL has Black, Gray 1 and Gray 2. Took me several sessions to figure out which gray tank was kitchen and which was bathroom. I used to watch the lights on the control panel (my first year as an rv owner) but soon gave up as they never indicated correctly. We have been pretty much full time since July 1 and I dump about every third day. No sewer hookup in our Ohio River campground so I usually get 2 to 3 trips per session with my 45 gallon tote. The good thing is I am less than 50 yards from the dump station so not a lot of effort, even easier now that I have a golf cart to pull my tote.
Nick, Sharon and Finnigan
Nick M is offline   Reply With Quote
Old 08-11-2015, 09:48 PM   #12
Twice's Avatar
We have a Coachmen Chaparral 336 TSIK, our panel shows 2 black and 2 grey tanks. It only has one black tank. Once I figured out which one was the "real" black tank, I use a piece of electrical tape to cover the "Black 2" label to end some of the confusion. Hope this helps some because Coachmen has the most worthless Owner's Manual I've ever seen!
Tammy and Tracey
and our doggie Jaq
2015 Ram 2500 Mega Cab w/ Cummins 4X4
2015 Coachmen Chaparral 336 TSIK
Twice is offline   Reply With Quote
Old 08-18-2015, 12:00 PM   #13
Originally Posted by scootingranny View Post
We have a Coachmen Chaparral 360IBL and the control panel shows two black tanks. After doing some online research and talking to others on this forum, I found out that a lot of units have a generic control panel. The two black tanks would most likely be for a unit with two separate bathrooms. We just ignore black tank #2
Scootingranny, how accurate do you feel your 360IBL is on the gauges. I have the 2015 model and for the life of me I just don't seem to trust it. My fresh water will drop from full to 1/3, completely skips 2/3. When I fill it up it registers every level fine, just when in use. Also we just came from an extended stay and used every drop of the fresh water. Various amounts in both greys and black. With all the water I used I only showed 1/3 in black and 1/3 in 1 grey. Any thougts on this. Thanks a bunch.
2015 Chaparral 360IBL 50th anniversary edition.
sau4u is offline   Reply With Quote
Old 08-18-2015, 03:20 PM   #14
Nick M's Avatar
Cheap level indicators
RV tank level indicators are a cheap/poor substitute for good tank level measuring electronics. Even cheaper than the Chinese tires provided by the OEM's. I've owner three fifth wheels and learned with my first one that the indicator lights are a relative indicator only and are rarely correct.
When we are living full time in the camper (over 40 nights this year) I empty about every 3 days except during really hot weather, then every other day. We rarely use the fresh water tank so it stays empty 90% of the time.
I'm sure the RV manufacturers could add quality tank level measuring devices but that adds $cost$ to the unit that most people would rather pass over to get prettier cosmetics. Just my humble opinion though.....
Old 08-18-2015, 03:32 PM   #15
just a thought. do you have washer / dryer prep? I have a 5th wheel that has this prep and it includes a separate tank and dump valve just for it. my monitor panel is also generic so the names on the panel do not match up with the function of the various tanks / valves.
CHICKDOE is online now   Reply With Quote
Old 08-18-2015, 05:14 PM   #16
wingedone's Avatar
I think you are right on.
I do have to say though, that except for my black tank monitor, my monitors have always worked just fine.
I can get the black tank down to empty, if I use the built in flusher, and then it works showing increasing contents. Then empty and time to flush again.
I thought I saw somewhere external sensor systems. If they work, seems we would have much less problems with them.
2011 Brookstone 354TS
2013 F350 SC 6.7 DRW
Swivelwheel 58DW
wingedone is offline   Reply With Quote
black, black tank, tank
